Rhino 8 SR Candidate 8 crashes
i’ve just updated SRC 8 and everytime i try to open a 3dm file (v8, v7) Rhino crashes,
anyone else with same problem?
System info:
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001)
License type: Comercial, build 2024-05-14
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.19
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
D:\00 RESOURCES\080_RH7\SafeLayout.rhp “SafeLayout” 1.1.0.2
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\CommandTracker\7.0.8201.28462\CommandTracker.rhp “CommandTracker” 7.0.8201.28462
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
D:\00 RESOURCES\080_RH7\blockeditnew202310240119\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24135.14001
Can you send in the model?
I would also block all the plugins the “do not ship with rhino” and restart Rhino. See if it will open then? This is not a solution, just trying to see if something we changed might have broke a plugin.
I blocked all the plugins the do not ship with rhino and Rhino works again.
I’m gonna enable one by one to identify the problem
It’s "SafeLayout.rhp “SafeLayout” 1.1.0.2
I loaded Safe Layout and it seems to load.
But the case here is that it crashes when opening and existing model? Is a there a sample model I can get? The contents can be mainly deleted out of the model. I suspect it has to do with having SafeLayout information embedded in that model.
Hi Scott,
as you said it seems to be something related with information embedded: i enabled again safelayout and the file has problems again
crash.3dm (94.6 KB)
