You should follow the steps outlined in Rhino 8 Crashes when I try to use Materials - #2 by nathanletwory to the letter. Specifically the starting of Rhino and not opening any document.
Thanks for the anser, I my problem is that even with a new model after reinstallation and or restart Rhino already crashes when I open the settings window…
Rhino 7 by the way is working perfectly fine.
I managed to change the Render device by command with RhinoCycles_SelectDevice and now everything seems to work. I hope apple finds a solution soon…
Good that you found a way. But it is clear that you always started a document when going through the motions, although I made it specifically clear to not do that. I’m glad in the end you have a temporary solution.
If you want to try using Metal again you could see if MacOS Sequoia 15.6 has these crashes fixed.
