My project file keeps crashing when I open the Environments, Rendering panel. I click on Environments and about a second or two later, it crashes. Here’s the report. Any help would be appreciated.
Many thanks
{“app_name”:“Rhinoceros”,“timestamp”:“2025-03-25 15:48:57.00 -0400”,“app_version”:“8.18”,“slice_uuid”:“2b2c0957-0660-399d-b337-1b9ae0e746c4”,“build_version”:“8.18.25076.15002”,“platform”:1,“bundleID”:“com.mcneel.rhinoceros.8”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 15.3.2 (24D81)”,“roots_installed”:0,“name”:“Rhinoceros”,“incident_id”:“B20CC041-7385-49D0-967B-23FC2656E721”}
“uptime” : 19000,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 502,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,2”,
“coalitionID” : 1211,
“osVersion” : {
“train” : “macOS 15.3.2”,
“build” : “24D81”,
“releaseType” : “User”
“captureTime” : “2025-03-25 15:48:56.6460 -0400”,
“codeSigningMonitor” : 1,
“incident” : “B20CC041-7385-49D0-967B-23FC2656E721”,
“pid” : 39906,
“translated” : false,
“cpuType” : “ARM-64”,
“roots_installed” : 0,
“bug_type” : “309”,
“procLaunch” : “2025-03-25 15:48:11.5471 -0400”,
“procStartAbsTime” : 469385012619,
“procExitAbsTime” : 470466553565,
“procName” : “Rhinoceros”,
“procPath” : “/Applications/Rhino 8.app/Contents/MacOS/Rhinoceros”,
“bundleInfo” : {“CFBundleShortVersionString”:“8.18”,“CFBundleVersion”:“8.18.25076.15002”,“CFBundleIdentifier”:“com.mcneel.rhinoceros.8”},
“storeInfo” : {“deviceIdentifierForVendor”:“DB3A9122-DA05-5B74-A447-B264DCE06125”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.mcneel.rhinoceros.8”,
“crashReporterKey” : “89F0AA9B-0209-BDAC-0A56-F361044D447D”,
“codeSigningID” : “com.mcneel.rhinoceros.8”,
“codeSigningTeamID” : “D6XDM4N99E”,
“codeSigningFlags” : 570491393,
“codeSigningValidationCategory” : 6,
“codeSigningTrustLevel” : 4294967295,
“instructionByteStream” : {“beforePC”:“fyMD1f17v6n9AwCRcuD/l78DAJH9e8Go/w9f1sADX9YQKYDSARAA1A==”,“atPC”:“AwEAVH8jA9X9e7+p/QMAkWfg/5e/AwCR/XvBqP8PX9bAA1/WcAqA0g==”},
“bootSessionUUID” : “C51A36E2-68C4-4FBC-A13D-BFD68367A236”,
“sip” : “enabled”,
“vmRegionInfo” : “0x6369142a5aa0 is not in any region. Bytes after previous region: 3748214037153 \n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n owned unmapped memory unmapped-unmapped [ 19.2M] rw-/rw- SM=PRV owned physical footprint (unmapped)\n—> \n UNUSED SPACE AT END”,
“exception” : {“codes”:“0x0000000000000001, 0x00006369142a5aa0”,“rawCodes”:[1,109302961035936],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGABRT”,“subtype”:“KERN_INVALID_ADDRESS at 0x00006369142a5aa0”},
“termination” : {“flags”:0,“code”:6,“namespace”:“SIGNAL”,“indicator”:“Abort trap: 6”,“byProc”:“Rhinoceros”,“byPid”:39906},
“vmregioninfo” : “0x6369142a5aa0 is not in any region. Bytes after previous region: 3748214037153 \n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n owned unmapped memory unmapped-unmapped [ 19.2M] rw-/rw- SM=PRV owned physical footprint (unmapped)\n—> \n UNUSED SPACE AT END”,
“asi” : {“libsystem_c.dylib”:[“abort() called”]},
“asiBacktraces” : [“[ERROR] FATAL NATIVE CRASH: segv\n0 libcoreclr.dylib 0x115e54c48 sigsegv_handler(int, __siginfo*, void*) + 56\n1 libsystem_platform.dylib 0x1822dade4 _sigtramp + 56\n2 Metal 0x18d1e3bec -[_MTLBinaryArchive materializeAirNTFromOnlineForSlice:entryList:] + 660\n3 Metal 0x18d1e5c90 __55-[_MTLBinaryArchive airntSerializeToURL:options:error:]_block_invoke.204 + 484\n4 libdispatch.dylib 0x1820f15b4 _dispatch_client_callout + 20\n5 libdispatch.dylib 0x182100e08 _dispatch_lane_barrier_sync_invoke_and_complete + 56\n6 Metal 0x18d1e57fc __55-[_MTLBinaryArchive airntSerializeToURL:options:error:]_block_invoke + 412\n7 libdispatch.dylib 0x1820f15b4 _dispatch_client_callout + 20\n8 libdispatch.dylib 0x182100e08 _dispatch_lane_barrier_sync_invoke_and_complete + 56\n9 Metal 0x18d1e5538 -[_MTLBinaryArchive airntSerializeToURL:options:error:] + 380\n10 libccycles.dylib 0x14ca8b18c ccl::MetalKernelPipeline::compile() + 2040\n11 libccycles.dylib 0x14ca8a7ec ccl::ShaderCache::compile_thread_func(int) + 180\n12 libccycles.dylib 0x14ca8f868 void* std::__1::__thread_proxy[abi:ue170006]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct>, ccl::ShaderCache::load_kernel(ccl::DeviceKernel, ccl::MetalDevice*, ccl::MetalPipelineType)::$_1>>(void*) + 52\n13 libsystem_pthread.dylib 0x1822a42e4 _pthread_start + 136\n[END ERROR]”],
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 67,
“threads” : [{“id”:429298,“threadState”:{“x”:[{“value”:268451845},{“value”:21592279046},{“value”:8589934592},{“value”:57187489546240},{“value”:0},{“value”:57187489546240},{“value”:2},{“value”:4294967295},{“value”:18446744073709550527},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:13315},{“value”:6912},{“value”:0},{“value”:18446744073709551569},{“value”:8391040504},{“value”:0},{“value”:4294967295},{“value”:2},{“value”:57187489546240},{“value”:0},{“value”:57187489546240},{“value”:6094627736},{“value”:8589934592},{“value”:21592279046},{“value”:21592279046},{“value”:4412409862}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478583300},“cpsr”:{“value”:4096},“fp”:{“value”:6094627584},“sp”:{“value”:6094627504},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478507860},“far”:{“value”:0}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:3924,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:79364,“symbol”:“mach_msg2_internal”,“symbolLocation”:80,“imageIndex”:68},{“imageOffset”:39672,“symbol”:“mach_msg_overwrite”,“symbolLocation”:480,“imageIndex”:68},{“imageOffset”:4764,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:68},{“imageOffset”:514636,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:160,“imageIndex”:69},{“imageOffset”:508588,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1212,“imageIndex”:69},{“imageOffset”:505652,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:588,“imageIndex”:69},{“imageOffset”:1094960,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:70},{“imageOffset”:1119048,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:676,“imageIndex”:70},{“imageOffset”:1119496,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:76,“imageIndex”:70},{“imageOffset”:243784,“symbol”:“_DPSNextEvent”,“symbolLocation”:660,“imageIndex”:71},{“imageOffset”:10099748,“symbol”:“-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:688,“imageIndex”:71},{“imageOffset”:190580,“symbol”:“-[NSApplication run]”,“symbolLocation”:480,“imageIndex”:71},{“imageOffset”:20584,“symbol”:“NSApplicationMain”,“symbolLocation”:888,“imageIndex”:71},{“imageOffset”:25204,“symbol”:“start”,“symbolLocation”:2840,“imageIndex”:72}]},{“id”:429453,“frames”:[{“imageOffset”:3924,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:79364,“symbol”:“mach_msg2_internal”,“symbolLocation”:80,“imageIndex”:68},{“imageOffset”:39672,“symbol”:“mach_msg_overwrite”,“symbolLocation”:480,“imageIndex”:68},{“imageOffset”:4764,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:68},{“imageOffset”:262808,“symbol”:“MachMessage::Receive(unsigned int)”,“symbolLocation”:80,“imageIndex”:29},{“imageOffset”:259620,“symbol”:“SEHExceptionThread(void*)”,“symbolLocation”:144,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:268451845},{“value”:17179869190},{“value”:0},{“value”:0},{“value”:0},{“value”:147347443023872},{“value”:1500},{“value”:0},{“value”:18446744073709550527},{“value”:1500},{“value”:0},{“value”:0},{“value”:0},{“value”:34307},{“value”:0},{“value”:0},{“value”:18446744073709551569},{“value”:8391058256},{“value”:0},{“value”:0},{“value”:1500},{“value”:147347443023872},{“value”:0},{“value”:0},{“value”:6096327920},{“value”:0},{“value”:17179869190},{“value”:17179869190},{“value”:6}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478583300},“cpsr”:{“value”:4096},“fp”:{“value”:6096326448},“sp”:{“value”:6096326368},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478507860},“far”:{“value”:0}}},{“id”:429454,“frames”:[{“imageOffset”:28700,“symbol”:“kevent”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:216304,“symbol”:“CorUnix::CPalSynchronizationManager::ReadBytesFromProcessPipe(int, unsigned char*, int)”,“symbolLocation”:396,“imageIndex”:29},{“imageOffset”:214108,“symbol”:“CorUnix::CPalSynchronizationManager::WorkerThread(void*)”,“symbolLocation”:140,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:1},{“value”:6216073772},{“value”:1},{“value”:0},{“value”:0},{“value”:0},{“value”:6097481356},{“value”:4293967296},{“value”:1000000},{“value”:2},{“value”:256},{“value”:256},{“value”:0},{“value”:256},{“value”:363},{“value”:1103806595328},{“value”:0},{“value”:0},{“value”:4294967295},{“value”:18446744073708551616},{“value”:0},{“value”:6216073728},{“value”:6216073772},{“value”:4294967295},{“value”:0},{“value”:1},{“value”:6097481519}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4662480112},“cpsr”:{“value”:2684358656},“fp”:{“value”:6097481456},“sp”:{“value”:6097481296},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478532636},“far”:{“value”:0}}},{“id”:429455,“frames”:[{“imageOffset”:38960,“symbol”:“poll”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:3404452,“symbol”:“ds_ipc_poll(_DiagnosticsIpcPollHandle*, unsigned long, unsigned int, void ()(char const, unsigned int))”,“symbolLocation”:184,“imageIndex”:29},{“imageOffset”:4138628,“symbol”:“ds_ipc_stream_factory_get_next_available_stream(void ()(char const, unsigned int))”,“symbolLocation”:908,“imageIndex”:29},{“imageOffset”:4130076,“symbol”:“server_thread(void*)”,“symbolLocation”:332,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:4294967295},{“value”:1166417034},{“value”:2},{“value”:3416115212},{“value”:176},{“value”:0},{“value”:1},{“value”:1},{“value”:2},{“value”:12},{“value”:105553170855744},{“value”:105553172942552},{“value”:2095104},{“value”:2043},{“value”:230},{“value”:11},{“value”:0},{“value”:105553173119152},{“value”:1},{“value”:6098054040},{“value”:4666414316,“symbolLocation”:0,“symbol”:“server_warning_callback(char const*, unsigned int)”},{“value”:4294967295},{“value”:6098054592},{“value”:4666734100,“symbolLocation”:67032,“symbol”:“OutString::hex(unsigned int, int, unsigned int)::digits”},{“value”:4666734068,“symbolLocation”:67000,“symbol”:“OutString::hex(unsigned int, int, unsigned int)::digits”},{“value”:1},{“value”:4666734100,“symbolLocation”:67032,“symbol”:“OutString::hex(unsigned int, int, unsigned int)::digits”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4665668260},“cpsr”:{“value”:1610616832},“fp”:{“value”:6098053968},“sp”:{“value”:6098053872},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478542896},“far”:{“value”:0}}},{“id”:429456,“frames”:[{“imageOffset”:6508,“symbol”:“__open”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:51784,“symbol”:“open”,“symbolLocation”:64,“imageIndex”:68},{“imageOffset”:3408128,“symbol”:“TwoWayPipe::WaitForConnection()”,“symbolLocation”:40,“imageIndex”:29},{“imageOffset”:3383352,“symbol”:“DbgTransportSession::TransportWorker()”,“symbolLocation”:232,“imageIndex”:29},{“imageOffset”:3379500,“symbol”:“DbgTransportSession::TransportWorkerStatic(void*)”,“symbolLocation”:12,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:0},{“value”:257},{“value”:256},{“value”:0},{“value”:0},{“value”:0},{“value”:1},{“value”:6208666692},{“value”:6208665916},{“value”:4667362616,“symbolLocation”:8,“symbol”:“module_critsec”},{“value”:256},{“value”:256},{“value”:0},{“value”:256},{“value”:5},{“value”:105553127899616},{“value”:0},{“value”:0},{“value”:6208666156},{“value”:6208666144},{“value”:0},{“value”:0},{“value”:0},{“value”:6208666128},{“value”:6098627056},{“value”:1},{“value”:19}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478555720},“cpsr”:{“value”:1610616832},“fp”:{“value”:6098626848},“sp”:{“value”:6098626800},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478510444},“far”:{“value”:0}}},{“id”:429457,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207408,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:308,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:3373620,“symbol”:“DebuggerRCThread::MainLoop()”,“symbolLocation”:208,“imageIndex”:29},{“imageOffset”:3373312,“symbol”:“DebuggerRCThread::ThreadProc()”,“symbolLocation”:232,“imageIndex”:29},{“imageOffset”:3372752,“symbol”:“DebuggerRCThread::ThreadProcStatic(void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:160},{“value”:0},{“value”:0},{“value”:6099200984},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:4596993592},{“value”:4596993656},{“value”:6099202272},{“value”:0},{“value”:0},{“value”:0},{“value”:1},{“value”:256},{“value”:105553173135360},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6099201104},“sp”:{“value”:6099200960},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}}},{“id”:429458,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:223592,“symbol”:“WaitForSingleObjectEx”,“symbolLocation”:80,“imageIndex”:29},{“imageOffset”:2197864,“symbol”:“CLREventBase::WaitEx(unsigned int, WaitMode, PendingSync*)”,“symbolLocation”:192,“imageIndex”:29},{“imageOffset”:1630052,“symbol”:“FinalizerThread::WaitForFinalizerEvent(CLREvent*)”,“symbolLocation”:48,“imageIndex”:29},{“imageOffset”:1630608,“symbol”:“FinalizerThread::FinalizerThreadWorker(void*)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175952,“symbol”:“ManagedThreadBase::FinalizerBase(void ()(void))”,“symbolLocation”:36,“imageIndex”:29},{“imageOffset”:1630936,“symbol”:“FinalizerThread::FinalizerThreadStart(void*)”,“symbolLocation”:88,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:27648},{“value”:0},{“value”:0},{“value”:160},{“value”:2},{“value”:0},{“value”:6099773304},{“value”:0},{“value”:768},{“value”:3298534884098},{“value”:3298534884098},{“value”:768},{“value”:0},{“value”:3298534884096},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:6216169016},{“value”:6216169080},{“value”:6099775712},{“value”:0},{“value”:2},{“value”:27648},{“value”:27649},{“value”:27904},{“value”:105553173078576},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6099773424},“sp”:{“value”:6099773280},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}}},{“id”:429459,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:224960,“symbol”:“SleepEx”,“symbolLocation”:160,“imageIndex”:29},{“imageOffset”:1187232,“symbol”:“TieredCompilationManager::BackgroundWorkerStart()”,“symbolLocation”:212,“imageIndex”:29},{“imageOffset”:1186800,“symbol”:“TieredCompilationManager::BackgroundWorkerBootstrapper1(void*)”,“symbolLocation”:104,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1186564,“symbol”:“TieredCompilationManager::BackgroundWorkerBootstrapper0(void*)”,“symbolLocation”:40,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:59392},{“value”:0},{“value”:0},{“value”:160},{“value”:0},{“value”:99999000},{“value”:6100347896},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:6216179768},{“value”:6216179832},{“value”:6100349152},{“value”:99999000},{“value”:0},{“value”:59392},{“value”:59393},{“value”:59648},{“value”:105553173079168},{“value”:6478809264,“symbolLocation”:0,“symbol”:“tlv_get_addr”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6100348016},“sp”:{“value”:6100347872},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}}},{“id”:429496,“name”:“com.apple.NSEventThread”,“threadState”:{“x”:[{“value”:268451845},{“value”:21592279046},{“value”:8589934592},{“value”:396936582529024},{“value”:0},{“value”:396936582529024},{“value”:2},{“value”:4294967295},{“value”:18446744073709550527},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:92419},{“value”:0},{“value”:0},{“value”:18446744073709551569},{“value”:8391040504},{“value”:0},{“value”:4294967295},{“value”:2},{“value”:396936582529024},{“value”:0},{“value”:396936582529024},{“value”:6105505896},{“value”:8589934592},{“value”:21592279046},{“value”:21592279046},{“value”:4412409862}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478583300},“cpsr”:{“value”:4096},“fp”:{“value”:6105505744},“sp”:{“value”:6105505664},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478507860},“far”:{“value”:0}},“frames”:[{“imageOffset”:3924,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:79364,“symbol”:“mach_msg2_internal”,“symbolLocation”:80,“imageIndex”:68},{“imageOffset”:39672,“symbol”:“mach_msg_overwrite”,“symbolLocation”:480,“imageIndex”:68},{“imageOffset”:4764,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:68},{“imageOffset”:514636,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:160,“imageIndex”:69},{“imageOffset”:508588,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1212,“imageIndex”:69},{“imageOffset”:505652,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:588,“imageIndex”:69},{“imageOffset”:1442424,“symbol”:“_NSEventThread”,“symbolLocation”:148,“imageIndex”:71},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}]},{“id”:429500,“frames”:[{“imageOffset”:6864,“symbol”:“read”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:50948,“symbol”:“SignalHandlerLoop”,“symbolLocation”:80,“imageIndex”:32},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:1},{“value”:37},{“value”:24},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:4615633776},{“value”:4615617352,“symbolLocation”:220,“symbol”:“SystemNative_HandleNonCanceledPosixSignal”},{“value”:41},{“value”:6},{“value”:10240},{“value”:6106656272},{“value”:12938884208},{“value”:3},{“value”:105553128177664},{“value”:0},{“value”:115},{“value”:0},{“value”:0},{“value”:1},{“value”:270008320},{“value”:4615651328},{“value”:13801588080},{“value”:4615651328},{“value”:4615651328},{“value”:4615651328}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4615620356},“cpsr”:{“value”:2684358656},“fp”:{“value”:6106656704},“sp”:{“value”:6106656608},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478510800},“far”:{“value”:0}}},{“id”:429503,“frames”:[{“imageOffset”:28700,“symbol”:“kevent”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:39388,“symbol”:“SystemNative_WaitForSocketEvents”,“symbolLocation”:76,“imageIndex”:32},{“imageOffset”:13804572076,“imageIndex”:73},{“imageOffset”:13804806636,“imageIndex”:73},{“imageOffset”:13739374192,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1462140,“symbol”:“ThreadNative::KickOffThread(void*)”,“symbolLocation”:172,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:4},{“value”:0},{“value”:0},{“value”:5773958656},{“value”:1024},{“value”:0},{“value”:0},{“value”:0},{“value”:6478809264,“symbolLocation”:0,“symbol”:“tlv_get_addr”},{“value”:6107229704},{“value”:13804571968},{“value”:13805199144},{“value”:13805554736},{“value”:11520},{“value”:11264},{“value”:48378511633664},{“value”:363},{“value”:105553128178384},{“value”:0},{“value”:6107229152},{“value”:5773958656},{“value”:0},{“value”:124},{“value”:6107229704},{“value”:4667207856,“symbolLocation”:16,“symbol”:“vtable for DebuggerU2MCatchHandlerFrame”},{“value”:5773777920},{“value”:6107229728},{“value”:0},{“value”:6478809264,“symbolLocation”:0,“symbol”:“tlv_get_addr”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4615608796},“cpsr”:{“value”:1610616832},“fp”:{“value”:6107228896},“sp”:{“value”:6107228864},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478532636},“far”:{“value”:0}}},{“id”:429505,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:1160812,“symbol”:“Thread::DoAppropriateWaitWorker(int, void**, int, unsigned int, WaitMode)”,“symbolLocation”:696,“imageIndex”:29},{“imageOffset”:1141604,“symbol”:“Thread::DoAppropriateWait(int, void**, int, unsigned int, WaitMode, PendingSync*)”,“symbolLocation”:68,“imageIndex”:29},{“imageOffset”:1515760,“symbol”:“WaitHandleNative::CorWaitOneNative(void*, int)”,“symbolLocation”:160,“imageIndex”:29},{“imageOffset”:13867950120,“imageIndex”:73},{“imageOffset”:13739532520,“imageIndex”:73},{“imageOffset”:13739374068,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1462140,“symbol”:“ThreadNative::KickOffThread(void*)”,“symbolLocation”:172,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:18944},{“value”:0},{“value”:0},{“value”:160},{“value”:0},{“value”:499999000},{“value”:6108112296},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:5511349304},{“value”:5511349368},{“value”:6108115168},{“value”:499999000},{“value”:0},{“value”:18944},{“value”:19457},{“value”:19712},{“value”:105553173015616},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6108112416},“sp”:{“value”:6108112272},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}}},{“id”:429509,“name”:“.NET ThreadPool Worker”,“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:14336},{“value”:0},{“value”:0},{“value”:160},{“value”:20},{“value”:0},{“value”:6110406056},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:5603973688},{“value”:5603973752},{“value”:6110408928},{“value”:0},{“value”:20},{“value”:14336},{“value”:14337},{“value”:14592},{“value”:105553173214992},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6110406176},“sp”:{“value”:6110406032},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}},“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:223496,“symbol”:“PAL_WaitForSingleObjectPrioritized”,“symbolLocation”:76,“imageIndex”:29},{“imageOffset”:1516276,“symbol”:“WaitHandle_CorWaitOnePrioritizedNative”,“symbolLocation”:76,“imageIndex”:29},{“imageOffset”:13739411060,“imageIndex”:73},{“imageOffset”:13867574864,“imageIndex”:73},{“imageOffset”:13867577964,“imageIndex”:73},{“imageOffset”:13867548096,“imageIndex”:73},{“imageOffset”:13739544612,“imageIndex”:73},{“imageOffset”:13739374068,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1462140,“symbol”:“ThreadNative::KickOffThread(void*)”,“symbolLocation”:172,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}]},{“id”:429510,“name”:“.NET ThreadPool Worker”,“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:17408},{“value”:0},{“value”:0},{“value”:160},{“value”:19},{“value”:999997000},{“value”:6110979496},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:4597023288},{“value”:4597023352},{“value”:6110982368},{“value”:999997000},{“value”:19},{“value”:17408},{“value”:17409},{“value”:17664},{“value”:105553173137904},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6110979616},“sp”:{“value”:6110979472},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}},“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:223496,“symbol”:“PAL_WaitForSingleObjectPrioritized”,“symbolLocation”:76,“imageIndex”:29},{“imageOffset”:1516276,“symbol”:“WaitHandle_CorWaitOnePrioritizedNative”,“symbolLocation”:76,“imageIndex”:29},{“imageOffset”:13739411060,“imageIndex”:73},{“imageOffset”:13867574864,“imageIndex”:73},{“imageOffset”:13867577964,“imageIndex”:73},{“imageOffset”:13867548096,“imageIndex”:73},{“imageOffset”:13739544612,“imageIndex”:73},{“imageOffset”:13739374068,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1462140,“symbol”:“ThreadNative::KickOffThread(void*)”,“symbolLocation”:172,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}]},{“id”:429512,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:223112,“symbol”:“CorUnix::InternalWaitForMultipleObjectsEx(CorUnix::CPalThread*, unsigned int, void* const*, int, unsigned int, int, int)”,“symbolLocation”:1656,“imageIndex”:29},{“imageOffset”:1160812,“symbol”:“Thread::DoAppropriateWaitWorker(int, void**, int, unsigned int, WaitMode)”,“symbolLocation”:696,“imageIndex”:29},{“imageOffset”:1141604,“symbol”:“Thread::DoAppropriateWait(int, void**, int, unsigned int, WaitMode, PendingSync*)”,“symbolLocation”:68,“imageIndex”:29},{“imageOffset”:1515760,“symbol”:“WaitHandleNative::CorWaitOneNative(void*, int)”,“symbolLocation”:160,“imageIndex”:29},{“imageOffset”:13867950120,“imageIndex”:73},{“imageOffset”:13739508912,“imageIndex”:73},{“imageOffset”:13739374068,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},{“imageOffset”:1174472,“symbol”:“ManagedThreadBase_DispatchOuter(ManagedThreadCallState*)”,“symbolLocation”:260,“imageIndex”:29},{“imageOffset”:1175860,“symbol”:“ManagedThreadBase::KickOff(void ()(void), void*)”,“symbolLocation”:32,“imageIndex”:29},{“imageOffset”:1462140,“symbol”:“ThreadNative::KickOffThread(void*)”,“symbolLocation”:172,“imageIndex”:29},{“imageOffset”:250332,“symbol”:“CorUnix::CPalThread::ThreadEntry(void*)”,“symbolLocation”:380,“imageIndex”:29},{“imageOffset”:29412,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:74},{“imageOffset”:8444,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:74}],“threadState”:{“x”:[{“value”:260},{“value”:0},{“value”:17664},{“value”:0},{“value”:0},{“value”:160},{“value”:1},{“value”:999999000},{“value”:6112126408},{“value”:0},{“value”:0},{“value”:2},{“value”:2},{“value”:0},{“value”:0},{“value”:0},{“value”:305},{“value”:8391058040},{“value”:0},{“value”:5604017208},{“value”:5604017272},{“value”:6112129248},{“value”:999999000},{“value”:1},{“value”:17664},{“value”:17665},{“value”:17920},{“value”:105553173215312},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6478776468},“cpsr”:{“value”:1610616832},“fp”:{“value”:6112126528},“sp”:{“value”:6112126384},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:6478522092},“far”:{“value”:0}}},{“id”:429527,“frames”:[{“imageOffset”:18156,“symbol”:“__psynch_cvwait”,“symbolLocation”:8,“imageIndex”:68},{“imageOffset”:30868,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1204,“imageIndex”:74},{“imageOffset”:207380,“symbol”:“CorUnix::CPalSynchronizationManager::ThreadNativeWait(CorUnix::_ThreadNativeWaitData*, unsigned int, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:280,“imageIndex”:29},{“imageOffset”:206500,“symbol”:“CorUnix::CPalSynchronizationManager::BlockThread(CorUnix::CPalThread*, unsigned int, bool, bool, CorUnix::ThreadWakeupReason*, unsigned int*)”,“symbolLocation”:348,“imageIndex”:29},{“imageOffset”:224960,“symbol”:“SleepEx”,“symbolLocation”:160,“imageIndex”:29},{“imageOffset”:1166296,“symbol”:“Thread::UserSleep(int)”,“symbolLocation”:216,“imageIndex”:29},{“imageOffset”:1468100,“symbol”:“ThreadNative::Sleep(int)”,“symbolLocation”:156,“imageIndex”:29},{“imageOffset”:13867997340,“imageIndex”:73},{“imageOffset”:13818278204,“imageIndex”:73},{“imageOffset”:13739374068,“imageIndex”:73},{“imageOffset”:2998388,“symbol”:“CallDescrWorkerInternal”,“symbolLocation”:132,“imageIndex”:29},{“imageOffset”:1378184,“symbol”:“DispatchCallSimple(unsigned long*, unsigned int, unsigned long, unsigned int)”,“symbolLocation”:272,“imageIndex”:29},{“imageOffset”:1461924,“symbol”:“ThreadNative::KickOffThread_Worker(void*)”,“symbolLocation”:148,“imageIndex”:29},
