Rhino 8 CPU Overload
Task Manager.png - Test.3dm
(I have attached ‘Wrong Material Icon Update.png’ too because of I don’t know whether it could be correlated or not, otherwise I’ll open another post, thank you)
Test.3dm (886.7 KB)
Dear McNeel, dear Forum,
like other users CPU goes overloading.
i.e. Loading attached file ‘Test.3dm’ → Select wall → Properties → click on Material → overload CPU (just after several seconds opens Material Panel)
i.e. Loading Rhino Sample Models ‘SubD Helmet.3dm’ as soon as I apply a textured material from Rhino Library goes in overload without any chance to do nothing, although I can use simple Window programs yet. Techincally Rhino doesn’t crash, just think :-).
In my case something let me think the issue could be caused by using textured materials. In the attached file seems to be no textures, but I tried it. No issue with files without textures.
At first I thought a different need to manage ram resources from Rhino too, no issue with Blender Cycles, I had just 6 GB, but after upgrading to 12 I have the same issue
Thank you,
Bartle
PS I hope I was clear, English isn’t my language, sorry.
System Info:
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Stand-Alone
Expires on: 2024-02-09
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 12Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1060 6GB (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
This should be fixed in what will become Rhino 8.5. I have sent you a link in a direct message to try.
edit/addendum:
The material icon issue you are seeing is because you have Viewport Sharpness set to something non-zero. In anything prior to Rhino 8.4 this was still a bit of a bug, but with Rhino 8.5 in the very least all of that has been fixed and stabilized. Parts that have been improved:
  • Viewport Sharpness actually works
  • Multiple GPU rendering possible (same rendering technology)
  • Automatic resolution division in the viewport through heuristics by Cycles (in 8.3 there is a non-functional Viewport Responsiveness slider - in 8.5 this has been dropped since it is no longer required).
  • Much improved handling of recompiling kernels. A couple of new buttons are available in the Rhino Render options dialog page
  • A whole load of fixes to materials, decals, color mask, etc
When you say 'S’upport. Wow.
Everything solved. You made may day.
A bit unresponsive in some cases, but it doesn’t matter when you are in love, Rhino user since Rhino 2, then I know to have an old PC.
Thank you… thank you very much indeed.
Best regards,
Bartle
Have fun using Rhino 8 :slight_smile:
I just updated to Rhino 8.5 and my CPU jumps to 100% use whenever I type any command. I did not have this issue with 8.4. Help? :slight_smile:
Does this happen when you type _Box in a completely empty document?
Yes it was happening with the _Box command. I uninstalled and reinstalled and seems to be fine now.
ok, let’s hope that it was the reinstall needed.
Yes, hopefully. Thank you Nathan.
