Slow performance in material editor
I don’t care about UI. I have set it up to be close to V7 and I use custom shortcuts mostly.
V8 is terribly slow compared to V7 and, knowing I have to be learning it, I don’t have the patience and I can’t afford wasting my time. With each V8 session it takes 30 min or so before I go back to V7.
Anything related rendering is absolutely no-go zone (materials, environment, mapping etc) and it’s pity because I like the new push-pull and some new additions.
I keep explaining myself that reason is below the keyboard (literally) but I can’t afford the machine that would be significantly faster than the one I am having. So, some of the V8 problems may be related to the faster computation demand.
hi @Piotr, to start with: what’s your _SystemInfo?
If you can quantify any of the statements it might help to make things better. Things like ‘terribly slow’ or ‘absolutely no-go zone’ doesn’t give much information on what is happening at your end.
In my world ‘terribly slow’ means more than 10 sec. and this is how much it takes to load, edit or remove materials from panel, Same for environments.
Very often, after manipulations of such kind, the overall performance drops significantly and there is no, or delayed response from my 3d mouse. No such things in V7.
It looks like V7 is better optimised for older machines like mine:
Rhino 8 SR6 2024-3-26 (Rhino 8, 8.6.24086.11001, Git hash:master @ 8e3b686f596bb6443e56e6dbecf0f54f4888713a)
License type: Commercial, build 2024-03-26
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 7-28-2023 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.18 30.0.13045.18005
> Integrated accelerated graphics device with 6 adapter port(s)
Primary OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 7-28-2023 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.18 30.0.13045.18005
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 7-28-2023
Driver Version: 30.0.13045.18005
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Cyberstrak\R7\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24086.11001
Thanks for the post. I find myself experiencing the same thing with the no-go zones you mentioned, giving up and going back to R7. In addition to the bugs, most actions seem slower in R8 for me except for the shaded viewport display, which is super fast.
I’ve reasoned that I’ll need to buy a new computer in order to use R8, and so far it wouldn’t be for much benefit. I hope that’s not true but I’m afraid it might be.
SystemInfo-R7
Rhino 7 SR37 2024-1-4 (Rhino 7, 7.37.24004.15001, Git hash:master @ e428f0ecb09d755f844c48e5098aba5f8baf55fa)
License type: Commercial, build 2024-01-04
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
C:\Users*\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
Z:\Shared\Library\Software\Rhinoceros\Others\LayerRenameTools.rhp “Rhino.NET SDK” 0.0.0.0
C:\Users*\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24004.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24004.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24004.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.37.24004.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24004.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24004.15001
C:\Users\Armen\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
SystemInfo-R8
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
@Piotr how does this page look at your end in options>rendering?
I have the same problem since Rhino8. Material editor is much slower then in Rhino 7 or older…
Rhino 8 SR6 2024-3-19 (Rhino 8, 8.6.24079.11001, Git hash:master @ 0d13b06881495403bd28e1cee93f8c8ea0baec7c)
License type: Kommerziell, Build 2024-03-19
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.16
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Total Video Memory: 8 GB
C:\Users\j.kronsbein\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24079.11001
V8
V7
You might want to make two changes for now to regain a bit more performance while we look into this:
  1. Nudge the sharpness slider one or two notches to the left from pixel perfect. This setting affects both previews and Raytraced.
  2. In Tools > Options > Advanced search for PreviewSamples and set it to something lower, say 10. This setting affects only previews.
Done that. I will write later about my experience.
Edit:
It is still slow. To display the material palette takes ca. 2min!
Windows hourglass can spinn for up to 20-30 sec. after leaving material panel.
lol it takes 5 min. how possible to close preview?
In v8.9 one can turn off the thumbnails by setting EnableGLPreview and EnablePreview to false in Advanced settings and restarting Rhino.
EnablePreview is for rendered previews and EnableGLPreview is for the initial quick preview. Maybe try to turn off the rendered previews first and see if that helps. Also one can try to turn off both and see if that helps performance.
Please fix this issue. It’s so painful. None of your suggestions work.
hi @aidan.newsome
can you run _SystemInfo in Rhino and post back the results?
Are you saying that disabling Rendered previews or OpenGL preview have no noticeable effect on performance?
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Primary display and OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Total Video Memory: 16 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.0.0
C:\Users\Aidan\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\Aidan\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.20.0.16185
C:\Users\Aidan\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\LookXRender\1.0.1\LookXRender.rhp “LookXRender” 1.0.1.0
C:\Users\Aidan\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
Yeah, for me they have zero noticeable effect on performance. Thanks, Gijs.
hi @aidan.newsome To make sure there is no influence of third party applications when investigating this issue, could you disable all of them and see if the issue persists?
Additionally, if you can send a model that shows the performance issue, we can have a closer look to try and find the bottleneck.
Large and/ or confidential models can be uploaded here.
yes please fix the material previews in the material tab. I can see each of my material thumbnail trying very hard to render in cycles. This is making texture heavy files almost unusable.
The Rhino 7 material tab is much faster.
Same problem here. When dealing with larger files with lots of materials the material tab with its previews buffering makes the file almost unusable in R8.
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 96GB)
.NET 7.0.20
Primary display and OpenGL: NVIDIA GeForce RTX 4080 SUPER (NVidia) Memory: 16GB, Driver date: 10-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.03
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #2
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 10-25-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-15-2024
Driver Version: 32.0.15.6603
Total Video Memory: 16376 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.2.0.1589
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
The CPU goes through the roof just by opening the material tab
Hi Elias -
See this post:
Also, please post a screenshot of the material editor.
