Material Panel Samples saturate CPU
Im encountering an abnormal problem of speed when ifm affecting materials to layers of my scene.
Trying to see with you if there is a way to solve it with some settings.
When im reaching a certain numbers of material in a scene (around 10) Everytime im opening the material panel or the list of material in Rhino, Samples seem to take much time to display and this is almost blocking my computer, sturating the CPU (see screenshot attached).
My CPU though is a brand new AMD Ryzen Threadripper 7980X 64-Cores
Does someone have an idea about this?
Below , my System info.
Vincent
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commerciale, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 256GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
I think this is… normal behaviour, apparently.
I think many have just changed to the tree view, given the usefulness of the previews seems limited anyway. This stops the constant sample re-rendering.
Ok :slight_smile: that is a step.
Thanks you.
i dont see much performance improvement, yet it appears it does not flickr (rerendering the preview spheres) it still impacts the performance dramatically, at least on mac that becomes devastatingly slow to work with having many materials in the file.
i basically never touch that panel if i dont have to
Tools > Options > Advanced, search for PreviewSamples. Set to 10 or so. Furthermore in Rhino Render bump viewport sharpness one step to the left. Or two. This affects the resolution used to raytrace. More to the left means larger pixels (blockier) for viewport and previews.
Btw, do you have VRay set as your current renderer? If so then the above suggestions don’t matter
Yes is is set as my current renderer.
Do the CPU spikes still happen when you set Rhino Render as the current renderer?
It happen with AND without Vray Set as current renderer
Just as an extra test, does it still happen with also the V-Ray plug-in disabled?
Tomorrow we should have 8.7 service release out, meaning 8.8 service release candidate will be available as well. Please try tomorrow updating to that (Help > Check For Updates… - set Update Frequency to Service Release Candidate and click Check Now… to get the link to the latest service release candidate).
Yeah it still happens.
I made a recording of opening a file with over a couple hundred materials. Once opened Rhino settles in at 0-1% CPU usage.
Maybe you can create a recording to see what you’re doing that is causing the CPU usage? If you don’t know how to record your screen I recommend Open Broadcaster Software (OBS), which I used myself.
Hello Nathan,
Ah. Scuse me during the last test my Vray was actually not unactivated.
Needed to restart Rhino to get it completely off.
So this let me the time to check oher things also in this condition.
I Confirm this problem of Vray material displaying si NOT happening when Vray is off.
It is still happening a little bit but but much less.
About this interoperability between Rhino And Vray in general it seems that Chaos would need to optimize some things. For example There is still a problem with Clipboard operations and deleting at one point when many Vray assets are loaded. And this happen only when Vray plugin is On. (i created another topic about that).
Do you think it yould be convenient to open a tichet about this in the Choas support?
It probably would be good to alert them of the issue.
But it is good to hear that Rhino on its own isn’t that big of an issue.
