Rhino 8 BETA no base color blending
Hi everyone
In Rhino 8 it doesn’t seem possible to blend a tiled diffuse texture and the material base color.
That is perfectly OK in Rhino 7 and 6
Rhino 7
Rhino 8 BETA
It also appears that Cycles completely ignores texture tiling (or lack there of) in Rhino 8:
probably related to this issue: Rhino 8 BETA no map tiling
The image above is produced by manually setting some properties of the materials, so we get the tiling works, but blending still doesn’t work neither in decal or modulate texture mode
@Nikolay AFAIK there are three ways to achieve this, see attached example file, and here they all seem to work ( though the blend material shows a bug in the render preview):
blend.3dm (577.5 KB)
My texture is not tiled and repeated twice along the U. So I expect to see the material color where the UV space is out of the image. The problem seem to be with the TIFF image that I have. Or rather how Rhino 8 interprets the alpha channel
Rhino 8
Rhino 7
for jpgs it works out of the box, but there is no alpha there,
PNGs with alpha look “broken” as well:
Rhino 8
Rhino 7
This is all rendered view, the mapping in raytraced view in 8 is completely broken
my build is 8.0.23297.13303 from Oct-24th
the png texture:
image_67802
base color blending works with Physically Based material
Custom material blending is apparently broken, and extension settings aren’t applied.
I’ve logged:
  • RH-77920 Custom material base color blending doesn’t work
  • RH-77921 Texture extension settings aren’t set
If may I add:
Repeat/Tile is not working for Cycles either
That is the texture extension bug I logged.
