Rhino 8.6 bug - white text on white background
I wish I could read white text on white background. You can see good example of this text in the slider settings window.
Not seeing that here. Have you changed any settings? You can revert to defaults with the Reset command.
Please post your SystemInfo
https://discourse.mcneel.com/t/please-read-this-if-you-are-logging-a-bug-or-issue/173971/3
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 192GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
Windows 10 made clear distinction between low contrast themes and high contrast themes. It tells the user whether the current theme is low contrast or high contrast. Furthermore, it allows the user to make several custom themes and to give them different names. Windows 11 is much more messy. It is difficult to figure out whether current theme is low contrast or high contrast. Apparently all background picture themes are low contrast and all solid background themes are high contrast. I purchased Rhino 8 to get dark user interface, so I must have dark, solid background. If Rhino 8 is incompatible with the high contrast themes, it probably means that I have wasted money. According to Windows 11 high contrast themes are called “contrast themes” and low contrast themes are just called “themes.” When I set the theme to “theme” and “turn on dark mode systemwide” on, Windows 11 still displays plenty of white color - it is called “accent color.” As far as I can tell, the only way to eliminate white color from the user interface is using “contrast theme.”
Similar bug was reported here: Rhino 8.7 bugs - invisible cross and text
thanks @andrew.nowicki for reporting
RH-81648 Slider settings does not work well in dark mode
