Yes that is correct.
I find this interesting, I wonder what the problem is.
For me the Windows 10 update has been problematic. Ever since I had that installed I have been unable to build Rhino on that machine. Visual Studio 2022 just keeps thinking some SDKs aren’t installed, even though they are. I am however able to start Rhino 8.21 and 8.22 just fine.
Now that RhinoCycles.rhp is disabled the other plugins load and operate fine.Did RhinoCycles.rhp get patched in 8.21? Or is it a bigger issue with win10?
I updated to 8.21.25168.13001 last night and the issue persists. Any other ideas? I’m currently using arctic mode with render materials turned on as a stop gap measure.
The crash report you sent in looks like the post I found here: https://stackoverflow.com/q/78598141 .
The reporter mentions that they were able to fix this by repairing one of the redistributable installs:
I personally managed to restore normal operation of my programs, by pressing
RepairinMicrosoft Visual C++ 2015-2022 Redistributable (x64) - 14.40.33810, which restoredC:\Windows\System32\msvcp140.dllto version14.40.33810.0.
@benji.cox can you please try repairing this on your system?
the repair option can be found here..
- Go to Control Panel > Programs > Programs and Features.
- Right-click Microsoft Visual C++ Redistributable and choose Repair.
That was it. Thank you!
I’m glad this worked!
I just had the same issue, and repairing Microsoft Visual C++ Redistributable solved it. Rhino 8.21 and Rhino 8.22. The crashing occurred after applying Windows updates, which seems to have touched that redistributable, according to the date in Settings → Apps. For anyone else with this issue, there are a lot of similarly named redistributables: look for one with a recent install/modification date, or one named like 2015-2023.
Interestingly this issue recurred for me after I uninstalled an optional windows feature.
Sounds like the Windows installation procedures mess up things. Did the previous fix work here too?
yes. repairing the same C++ libraries fixed it.
I need to stop updating windows 10. I just installed the newest update and it broke the x64 runtimes again
My issue also got solved with this troubleshoot, thank you so much for sharing.
