.Net Framework Plugin not working in Rhino 8
Can plugins targeting .Net Framework 4.8 work in Rhino 8 running under .Net Core? I thought the answer was no. But one of my plugins is targeting .Net Framework 4.8 and it works under Rhino running under .Net core.
Now another of my plugin, also targeting .Net Framework 4.8 does not work with Rhino 8 running under .Net core. It does not give any error but the commands just don’t work.
What am I missing? Why one plugin is working and another doesn’t?
I ran the Compat tool mentioned here. The output is
Wb.ModelEstablishment.Rhino, Version=1.1.3.0, Culture=neutral, PublicKeyToken=null
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP  - Plugged in [99% battery remaining]
  Primary display and OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
        - Laptop lid is possibly closed
        - Windows Main Display attached to adapter port #1
        - Secondary monitor attached to adapter port #2
  Primary OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 7-23-2024
  Driver Version: 32.0.15.6076
  Z-Buffer depth: 24 bits
  Total Video Memory: 8 GB
  C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\WB_RHTrack (f1b547e5-c3af-478d-84ee-6804536a8bb2)\1.0.7346.25956\WB_RHTrack.rhp	"WB_RHTrack"	1.0.7346.25956
  C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp	"Datasmith Exporter"	5.4.3.0
  C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll	"Enscape.Rhino8.Plugin"	0.0.24138.1238
  C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ElefrontProperties (5db9285b-b408-41e2-b815-ed6ad84fd4a9)\1.0.0.0\ElefrontProperties.rhp	"ElefrontProperties"	1.0.0.0
  C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\WombatRhino\1.0.5.17\WombatRhino.rhp	"WombatRhino"	1.0.5.17
  C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.230\Ladybug.RH.Loader.rhp	"Ladybug.RH.Loader"	1.38.230.0
  C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.52.19\Pollination.RH.Loader.rhp	"Pollination.RH.Loader"	1.52.19.0
  C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRsceneImportForRhino.rhp	"V-Ray for Rhino VRscene Importer"
  C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp	"V-Ray for Rhino"
  C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Wb.ModelEstablishment.Rhino\1.1.3\Wb.ModelEstablishment.Rhino.rhp	"Wb.ModelEstablishment.Rhino"	1.1.3.0
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.12.24282.7001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
  C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp	"PanelingTools"
I’m assuming “doesn’t work” means Rhino 8 will not load it, correct?
If you modify the project to build against .NET 7, do you get errors?
<TargetFrameworks>net7.0;net48</TargetFrameworks>
Where can we find the plug-in that “doesn’t work”?
Thanks,
– Dale
Hi @dale,
Doesn’t work means, the plugin loads alright and there are no errors. But when I try any of the commands, nothing happens.
Modifying the project to build against .NET 7 would be complicated due other dependencies.
It is a plugin we develop in-house.
@Devang_Chauhan - can you pm me the plug-in?
– Dale
