Rhino 7 WIP_ ViewCaptureToFile
Hello everyone
I have an issue with command : viewcaptureToFile in Rhino 7 WIP,this command only save image with .PNG format, When when I try to save with .JPE or .Tif format nothing appearented in folder.
Could everyone in forum have the same issue ?
Saving as jpeg seems to work fine here…
View Capture to file and View capture to clipboard
Not working in WIP (7.0.20056.13055, 2/25/2020)
No images (.jpeg, .png, .tif, or .bmp) produced if output size is larger than screen resolution (1920 x 1080) with Scale set higher than 1. Also tried keeping Scale at 1 and dialing in size larger than screen resolution, i.e., 2000 X 1125; same fails.
When using View Capture to file the Command line reports "Image successfully saved as C:\Users\fred\Desktop\larger.jpg " ( or .tif, .png, .bmp)
Works in V6 SR24 (6.24.20055.18581, 2/24/2020)
@Helvetosaur Note OP’s use of Scale. ?
Is that a brass pull? Nice drawin’.
Hi Fred - that works fine here. Can you provide your SystemInfo and perhaps a file to reproduce this with?
I am seeing what @Fred_C is seeing here - the jpeg is not saved if I set the scale to something other than 1 larger than 1.3 and/or I give it a custom resolution…
image test.3dm (266.5 KB)
Fails with any setting/ combination that exceeds Screen res
Had the same issue today, filed some posts below.
Thanks guys. This works here on the built I’m running so I’ll downgrade to see if I can reproduce on 7.0.20056.13055.
All - I’m seeing this on 7.0.20056.13055 but it works fine in the latest in-house build of the day so this was fixed somewhere along the road.
Found this: (not found on earlier search)
Edit: Solved :white_check_mark:Fixed in WIP 7.0.20064.14095, 3/4/2020.
Hi Brenda, This is a decorator on the door.and it’s will be cast by mold.
