user38
October 20, 2021, 1:12pm
1
Good morning,
I have the Rhino 7 Evaluation version on my Mac and recently it has started freezing up my entire computer and nothing can be done on my computer unless I do a hard reset and then I lose work on anything and everything else I had open. I’ve been using Rhino for years and this has never happened before. After restarting, when trying to use Rhino again, it won’t open. It just stays on the “initializing” page and doesn’t move on. At this point I’m not sure what to do because it takes a full 24 hours after this happens for me to even be able to get Rhino open.
pascal
(Pascal Golay)
October 20, 2021, 3:19pm
2
Hello - can you please start Rhino and run the SystemInfo command, and copy/paste the results here?
user38
October 20, 2021, 3:38pm
3
I’ve copied it here:
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19002, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Evaluation, build 2021-05-07
License details: Stand-Alone
Expires on: 2021-11-17
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G103) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookPro12,1
Language: en-US (MacOS default)
Intel(R) Iris™ Graphics 6100 (OpenGL ver:4.1 INTEL-12.10.12)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Graphics 6100
Displays: Color LCD (227dpi 2x), DELL P2419H (93dpi 1x)
Graphics processors
Intel Iris Graphics 6100 (1536 MB)
Color LCD (1280 x 800)
DELL P2419H (1920 x 1080 @ 60 Hz)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.6.21127.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.6.21127.19002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.6.21127.19002
pascal
(Pascal Golay)
October 20, 2021, 5:06pm
4
Hello - please install the latest service release and see if that sorts it out.
https://www.rhino3d.com/download/rhino-for-mac/evaluation
user38
October 29, 2021, 4:45pm
5
Hello, I installed the latest service release and Rhino continues to still freeze my entire computer resulting in me having to hard restart my computer every time.
John_Brock
(John Brock)
October 29, 2021, 5:18pm
6
It looks like you’re trying to drive 2 monitors with an inadequate Intel GPU.
I assume you are using some sort of docking station to run the second monitor.
What happens if you run Rhino without the docking station or 2nd monitor?
Does the system freezing stop?
user38
October 29, 2021, 6:46pm
7
I am using 2 monitors. I have my Mac Book Pro and then a Dell Monitor that is connected to my laptop through an HDMI cord.
Once, I unplugged the monitor and only used Rhino on my laptop it did stop freezing. Please excuse me if I’m asking a dumb question, (Computers aren’t really my language) so in order for me to drive 2 monitors without Rhino crashing, my computer needs better Intel GPU?
John_Brock
(John Brock)
October 29, 2021, 6:56pm
8
If you need 2 monitors, you’ll need a new, more powerful Mac.
user38
November 1, 2021, 12:46pm
9
Thank you so much! I appreciate all of your help.
