Hello, I’m using the latest version of Rhino 7 and since recently the ‘layer’ panel doesn’t use the same settings for background color as the other panels which makes the text unreadable in the dark theme that I designed.
Is this a flaw in Rhino, or a bug in my theme? All I did was change the colors via the Preferences > Appearance.
As a workaround I set my text color to grey, but this looks horrible in the other panels. It used to be whitish. Anyway, in this picture it’s clear, on the left it correctly uses the dark background, but the layers panel is simply white and cannot be changed in any way. Some of the other panels also ignore the theme colors.
_Systeminfo:
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Educational, build 2024-04-16
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 31Gb)
Computer platform: LAPTOP - Plugged in [55% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 7-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.70
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-10-2024
Driver Version: 32.0.15.6070
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\ohmar\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp "ElefrontProperties" 1.0.0.0
C:\Users\ohmar\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp "NVIDIADenoiser.Windows" 0.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Users\ohmar\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp "Alerter"
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
