Hello
After updating to SR14 Twn2CrvsCrv component starts to show an error: “solution exception: Index was outside the bounds of the array” with a second guide curve plugged in. It did not happen before the update and broke a script which worked fine.
Twn2CrvsCrv_error_example.gh (7.6 KB)
Yes, see here: Twn2CrvsCrv doesn't work
It is fixed in R7 SR16, update your Rhino.
Thank you. I’ve found a way around it, but it’s great to know it works again.
