Rhino 7 Service Release Candidate Available
Rhino 7 SR25 Release Candidate 1 for Windows and Mac (7.25.22313) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac
Bugs Fixed:
  • GetObject: IPlane and SubCrv options were incorrectly made always available (RH-70946)
  • MoveUVNOn: SubD control points edited by MoveUVN did not apply (RH-49848)
  • Purge: Purge does not remove unused annotation style (RH-71104)
  • Rotate3D: Rotate3d: see the intersection (RH-71247)
  • SDK: DisplayBitmap reports incorrect height (RH-71155)
SDK Enhancement:
  • SDK: Allows CRhCurveBoolean not to print error messages (RH-70774)
Mac-Only Changes
Bugs Fixed:
  • RDK: Resample texture input problem / bugs (RH-70945)
Windows-Only Changes
Bugs Fixed:
  • Annotation: Text: Missing font detection did not recognize localized font names (RH-59268)
  • SDK: GhPython: Copy "Hint" of neighboring inputs or outputs (RH-54143)
Rhino 7 SR25 Release Candidate 2 for Windows and Mac (7.25.22318) is now available
Enhancements:
  • SDK: RhinoCommon: Exposed ON_NurbsCurve::ConvertSpanToBezier (RH-71249)
Rhino 7 SR26 Release Candidate 1 for Windows and Mac (7.26.22343) is now available
Bugs Fixed:
  • RDK:
    • Objects temporarily lost materials (RH-71854)
    • Strange colours in render content preview thumbnails (RH-71473)
Enhancements:
  • SDK: RhinoCommon: Exposed ON_BrepVertex::m_tolerance (RH-71671)
Rhino 7 SR26 Release Candidate 2 for Windows and Mac (7.26.22348) is now available
Enhancements:
  • Crash fixes
Rhino 7 SR27 Release Candidate 1 for Windows and Mac (7.27.23009) is now available
SDK Enhancement:
  • SDK: RhinoCommon: Expose CRhinoPrintInfo::m_textdot_size to RhinoCommon (RH-72325)
Bugs Fixed:
  • Display: Cycles rendered a blank viewport with OpenGL 2.1 (RH-71941)
Rhino 7 SR28 Release Candidate 1 for Windows and Mac (7.28.23041) is now available
Bugs Fixed:
  • File IO:
    • Leader exported to DWG pointed to a wrong place (RH-72074)
    • Updated Datakit libs to 2023.1 that supports reading SolidWorks 2023 files (RH-70604)
  • GumballAlignment: Axes directions of Gumball (align to object), UVN, MoveUVN were incorrect for control points on SubD-friendly curves (RH-72629)
  • Help: BooleanIntersection needs to be added to the list on History’s Help page. (RH-72462)
  • Licensing and Validation: License manager dialog pops under all other open windows (RH-71806)
  • RDK: "Properties: Materials" panel did not show options (RH-72737)
  • Rendering: Materials: Layers in Choose Layers dialog did not list in alphabetical order (RH-72595)
  • SDK: RhinoCommon: rs.ObjectColor() always returned A (transparency) value as 255 (RH-72572)
  • UDT: Flowed object and naked edges (RH-42841)
Rhino 7 SR28 Release Candidate 2 for Windows and Mac (7.28.23051) is now available
Bugs Fixed:
  • Angle: Incorrect with some edges (RH-73003)
  • Sun: Daylight saving in Eto dialog did not work properly (RH-73045)
Rhino 7 SR28 Release Candidate 3 for Windows and Mac (7.28.23058) is now available
Bugs Fixed:
  • Notes: Text in Notes panel was all selected when Rhino window regaining focus (RH-65292)
Rhino 7 SR29 Release Candidate 1 for Windows and Mac (7.29.23093) is now available
Bugs Fixed:
  • BlendEdge: Failed when chain-selecting edges with double-clicking (RH-73662)
  • Grasshopper: Line Dimension baking issue (RH-73286)
  • Rendering: Reflection on back faces looked different from front faces (RH-72717)
  • SDK: RhinoCommon: RhinoCommon SDK: Curve.GetDistancesBetweenCurves method does not work if curves do not share a similar direction (RH-73988)
  • Select: DoubleClick + Shift + CTRL Control Cage caused a hang (RH-73884)
Enhancements:
  • ShowDir: Direction color change did not persistent through sessions (RH-73171)
Regressions Fixed:
  • ExtractAnalysisMesh: Did not save vertex colors from Draft Angle Analysis (RH-73089)
  • File IO: Nested blocks in DWG read incorrect in Rhino (RH-72439)
  • SDK: RhinoCommon: Bug of Curve.OffsetOnSurface (RH-73651)
Bugs Fixed:
Rhino 7 SR30 Release Candidate 1 for Windows and Mac (7.30.23125) is now available
Bugs Fixed:
  • Grasshopper: “Mesh Brep” component not making closed mesh from closed Brep (RH-74187)
Rhino 7 SR30 Release Candidate 2 for Windows and Mac (7.30.23130) is now available
Bugs Fixed:
  • Minor bug fixes and optimizations.
Rhino 7 SR32 Release Candidate 1 for Windows and Mac (7.32.23191) is now available
Bugs Fixed:
  • BoxEdit: The panel causes a delay in History updates (RH-71250)
  • File IO: Import multipage PDF not scriptable (RH-75099)
  • ProjectToCPlane: ProjectToCplane: Fails on Edge (RH-75703)
  • SDK: RhinoCommon:
    • Curve.Trim bug (RH-75627)
    • Polyline.IsClosed should call ON_Polyline::IsClosed (RH-75351)
  • TextField: Area Field Override Incorrectly Applied Annotation Style Unit (RH-75384)
SDK Enhancement:
  • SDK: RhinoCommon: Added Radial dimension to a File3dmObjectTable (RH-75418)
Rhino 7 SR33 Release Candidate 1 for Windows and Mac (7.32.23213) is now available
SDK Enhancement:
  • SDK: RhinoCommon:
    • Allows access to displayed order of layers as shown in Layers panel. (RH-76087)
    • Added “Zoom Window” function (RH-75756)
Rhino 7 SR33 Release Candidate 2 for Windows and Mac (7.32.23234) is now available
Bugs Fixed:
  • SDK: Rhino C++ SDK break in CRhinoFileUtilities::GetRhinoApplicationDataFolder (RH-76240)
Bugs Fixed:
  • Installer: Smart App Control on Windows 11 blocks Rhino 7 installation (RH-76371)
Rhino 7 SR34 Release Candidate 1 for Windows and Mac (7.32.23258) is now available
Bugs Fixed:
  • CopyHole: UseLastDistance prevents command from finishing (RH-76911)
  • FilletEdge: On editing an edge fillet, added handles cannot be removed (RH-76301)
  • Rendering: Materials: Messed-up panel after SVG import (RH-76436)
Crashes Fixed:
  • SDK: GhPython: GhViewTable.Find causes System.StackOverflowException exception (RH-75083)
SDK Enhancement:
  • SDK: RhinoCommon: Exposed ON_Dimension::UpdateDimensionText (RH-76380)
Rhino 7 SR35 Release Candidate 1 for Windows and Mac (7.35.23280) is now available
Bugs Fixed:
  • IntersectTwoSets: Cannot output to layer of first or second set (RH-77288)
Rhino 7 SR36 Release Candidate 1 for Windows and Mac (7.36.23346) is now available
Bugs Fixed:
Rhino 7 SR37 Release Candidate 1 for Windows and Mac (7.37.24107) is now available
Mac-Only Changes
Bugs Fixed:
  • File IO: Import_DGN plugin does not load on V7 Mac (RH-81575)
Rhino 7 SR38 Release Candidate 1 for Windows and Mac (7.38.24338) is now available
Bugs Fixed:
  • Backport RH-79335 to Rhino 7 (RH-81018)
  • Help: Help file is found without index (RH-82776)
Regressions Fixed:
  • Grasshopper: Backported Area/Volume components from V8 GH1 to V7 (RH-80567)
Rhino 7 SR39 Release Candidate 1 for Windows and Mac (7.39.25314) is now available
Mac-Only Changes
Bugs Fixed:
  • Cursor tracking stops working during command on macOS Tahoe (RH-89546)
  • Settings: Trackpad Settings missing on Tahoe (RH-89545)
