Rhino 7 Service Release Available
Rhino 7 Service Release 16 for Windows and Mac (7.16.22067) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
  • Annotation: DimRadial: Radius and Diameter Dimension Text Were Incorrect (RH-67328)
  • Contour: Created open curves from closed sections of meshes (RH-66997)
  • Display: Point clouds imported from PLY files were invisible (RH-66750)
  • File IO:
    • Step Import failed to detect a planar NURBS if it was trivially trimmed (RH-67122)
    • Exports slightly non-planar surfaces to STEP as planes (RH-67211)
    • IGES export ignored the Units setting (RH-67142)
    • FBX headless import unexpectedly showed a dialog box (RH-66552)
    • FBX import did not read all textures (RH-66914)
    • Scripting PDF import interrupted by the “Embedded PDF fonts cannot be loaded” message appearing in a dialog box (RH-67067)
  • Length: Inconsistent on SubD Edges (RH-67078)
  • OSnap:Mid: OSnap Mid: Snapping on polysurface edge was incorrect (RH-67276)
  • RDK:
    • DotNet garbage collection crashed on exit (RH-66942)
    • CRhRdkMaterial::FromOnMaterial() did not set the material name for PBR materials (RH-67293)
    • Eto UI wrote incorrect strings to documents (RH-67213)
  • Rendering: "Use lights on layers that are off" option did not work (RH-66917)
  • Rendering: Cycles: Flipped wallpaper upside down (RH-67327)
  • Rendering: Decals: Selecting Properties > Decal crashed Rhino (RH-67140)
  • Rendering: Texture Mapping:
    • Hard to select mapping item in Properties panel (RH-66245)
    • Custom UV had artifacts on SubD, but not on mesh (RH-66487)
  • SDK: CRhinoObjectIterator did not respect all 'object_state' flags (RH-67230)
  • SDK: Python: IronPython is not reported for platform.python_implementation (RH-67339)
  • SDK: RhinoCommon:
    • LinetypeTable.FindName comments for return value are not clear (RH-67092)
    • Could not deserialize leaders (RH-61100)
Crashes Fixed:
  • File IO: Rhino silently crashed when reading a SLDASM file (RH-67118)
Enhancements:
  • Drag: Made possible to drag with Gumball even if EnableSelectedGripDrag or EnableSelectedObjectDrag is disabled in advanced settings (RH-67320)
  • File IO:
    • SOLIDWORKS Import - Supports up to version 2022 (RH-67502)
    • STEP export now converts non-rectangular planar surfaces to planes (RH-67060)
Regressions Fixed:
  • Annotation: Zooming in detail broke radius and diameter dimensions on arcs (RH-67054)
  • DevLoft: Issue when two rails met at one end (RH-67434)
  • MeshSplit: Mesh.Split() failure with user case (RH-63422)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Added an additional override to InstanceDefinitionTable.Modify for specifying/modifying Url and UrlTag fields (RH-67038)
    • Exposed more properties of an Ellipse (RH-67116)
Mac-Only Changes
Bugs Fixed:
  • Code Editor Control: GHPython script component crashed when using type() in script (RH-65457)
  • Eto: GroupBox on Mac could cause crashes (RH-67214)
  • Grasshopper: Save dialog popped up repeatedly when quitting with multiple Rhino and GH documents open (RH-57116)
  • Hyperlink: CMD-Click did not open URL in object on Mac (RH-67344)
Crashes Fixed:
  • 4View: Unnecessarily replacing views and pipelines multiple times caused a crash on Mac (RH-66953)
  • File IO: Crashed when meshing 3dm files from older versions on opening (RH-65537)
Enhancements:
  • Rendering: Materials: SBSAR image data is now stored in 3dm as PNG instead of TIFF (RH-67449)
Regressions Fixed:
  • Display: Technical mode did not draw silhouettes (RH-66777)
Windows-Only Changes
Bugs Fixed:
  • EditPythonScript: EditPythonScript and GHPython did not load (RH-67409)
  • ExtractMeshEdges: New geometry was not added to worksession active model (RH-67282)
  • ExtractMeshFaces: New geometry was not added to worksession active model (RH-67281)
  • ExtractMeshFacesByArea: New geometry was not added to worksession active model (RH-67283)
  • ExtractMeshPart: New geometry was not added to worksession active model (RH-67284)
  • RDK: Sun year might not be able to set smaller than 1980 (RH-67089)
  • Worksession: Copy and detaching issues (RH-67095)
Crashes Fixed:
  • SDK: RhinoCommon: Rhino.Inside Grasshopper Sweep2 was crashed by start and end points (RH-67456)
Enhancements:
  • Layer: Allows "Copy Objects to Layer" on context menu working with worksession attached objects (RH-56390)
  • Rendering: Materials: SBSAR image data is now stored in 3dm as PNG instead of TIFF (RH-66432)
Rhino 7 Service Release 17 for Windows and Mac (7.17.22102) is now available
Bugs Fixed:
  • MeshCylinder: Vertex normals of base cap pointed inwards (RH-67428)
  • PackageManager: Scriptable command was not pre-populating search (RH-67805)
  • SDK: RhinoScript: MeshMeshIntersection rhinoscript (VbScript) tolerance problem (RH-67504)
  • SpaceMouse: 'Auto Rotation Center' moved target very close to camera and caused objects far away to be clipped (RH-67392)
  • SubD: Edge sector coefficient evaluation was wrong for corner vertices (RH-67377)
Enhancements:
  • Display: Shows "Enable GPU detection" button when initializing of CUDA fails and GPU is disabled (RH-67747)
  • RecordAnimation: Supports creating animation from Raytraced viewport (RH-57903)
SDK Enhancement:
  • RDK: Added C++ and C# API for creating an OCS type ON_TextureMapping (RH-67578)
Tasks Completed:
  • Help: Rewrite the help and other docs for commands using the mesh detailed options dialog (RH-66828)
Mac-Only Changes
Bugs Fixed:
  • DocumentProperties: Changing units did not prompt for scaling the model (RH-67851)
  • Eto: Occasional crash in plugins panel on Mac (RH-67444)
  • Update System: Updating to 7.17 failed on MacOS (RH-67833)
Crashes Fixed:
  • ReduceMesh: Crashed on MacOS 12.3 (RH-67912)
Bugs Fixed:
  • Toolbar: Saving RUI file failed with menu items (RH-67926)
Regressions Fixed:
  • Annotation: Dot: Unicode Symbols (L Sep / Line Separator) visible in German Rhino (RH-67411)
SDK Enhancement:
  • SDK: 3dm export allows specifying a different unit system (RH-67485)
Rhino 7 Service Release 18 for Windows and Mac (7.18.22124) is now available
Bugs Fixed:
  • Color Picker: Central area intermittently was not what was actually used (RH-67326)
  • Curvature: Failed to mark max curvature on shallow curves (RH-68172)
  • Display:
    • Shadow showed through model in Rendered mode (RH-68522)
    • Empty dots slowed down performance (RH-68135)
  • File IO: FBX Export failed to set filetype properly unless it was the last argument in the list of options (RH-67758)
  • Geometry Core: ON_BezierSurface Loft made garbage (RH-67950)
  • Gumball: Did not work with viewport camera grips (RH-67784)
  • Help: InfinitePlane topic is tuned up (RH-68378)
  • NamedView: Selecting a named view and did nothing else caused the document to be modified (RH-67642)
  • PointDeviation: Hair scale did not change (RH-68001)
  • RDK:
    • Materials panel showed different material count than RenderMaterials table (RH-67902)
    • RenderContent.FromXml(str, RhinoDoc) incorrect behavior (RH-67920)
  • Rendering: Safe Frame Action Area lock changed the wrong value (RH-67695)
  • Rendering: Materials: PBR emission multiplier over 1 displayed black in Rendered mode (RH-67915)
  • SDK:
    • RhinoUpdateObjectGroups did not copy existing group user data (RH-67887)
    • mesh.Smooth() was mistakenly affected by Smooth command settings (RH-67886)
  • SDK: RhinoCommon:
    • Mesh.CreateFromCurveExtrusion flawed (RH-68211)
    • GetPolyline.SetStartPoint did not work (RH-68082)
  • SketchOnSrf: Left the base surface highlighted (RH-68007)
  • SubD: RadiateFind: Only worked on faces near the middle (RH-67849)
  • Trim: Failed when using Line option with ExtendCuttingLines=Yes (RH-67974)
  • Unlock: SubD edges could not be selected if they were ever locked (RH-68437)
  • UserText: Value could not be changed on the filtered list (RH-68246)
Crashes Fixed:
  • Unlock: Crashed with SubD objects that have points on and subobjects locked (RH-68408)
Enhancements:
  • SDK: RhinoCommon: ReplayHistoryResult.UpdateToSubD() missing (RH-68005)
Regressions Fixed:
  • Area: Failed on rectangles (RH-68376)
  • SquishInfo: Pattern can be recognized but the result was an empty text window (RH-66215)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Exposed ON_Brep::GetConnectedComponents (RH-68189)
    • Added a new Mesh.CreateFromSurfaceControlNet static function which calls ON_ControlPolygonMesh (RH-67893)
    • RhinoLayout.DisablePanelColorStyling() is made pubic (RH-67885)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Text: Graphik font on Mac missing typefaces (RH-68433)
  • BlendSrf: Did not accept values below 0.25 (RH-67489)
  • Grasshopper: Current definition was closed without warning (RH-68093)
  • Rendering: Materials: Selection problems (RH-67997)
  • Rendering: Post Effect: Curves Post Effect resulted in black render at higher resolutions (RH-67880)
  • StatusBar: Layer pane did not always display layer of selected object (RH-67836)
Incomplete Port:
  • Audit: Audit3dmFile to clipboard and file did not work (RH-67901)
Bugs Fixed:
  • Groundplane: GroundPlane: Settings in French did not display properly with 4K screen (RH-67803)
  • Installer: Rhino 7 type library named after Rhino 6 (RH-67373)
  • Rendering: Post Effect: Curves Post Effect resulted in black render at higher resolutions (RH-67999)
Rhino 7 Service Release 19 for Windows and Mac (7.19.22165) is now available
Bugs Fixed:
  • BlendSrf: Problem about interior shapes (RH-68315)
  • FilletEdge: Preview display performance dropped significantly (RH-68394)
  • Isolate: Opened the selection filter (RH-68303)
  • Join: RhinoJoinBreps produced an odd result (RH-68363)
  • PackageManager: Older public GH2 version installed over newer private GH2 version (RH-68355)
  • Panels: Divider panel style did not allow overriding (RH-68508)
  • RDK: Wireframe post effects did not work with RenderWindow and RenderInWindow (RH-67382)
    • Skylighting/reflection did not work correctly when HDRs had intensity multiplied (RH-68579)
    • Flipped wallpaper upside down (RH-67327)
  • Rendering: Materials: Replacing a PBR material of a layer with another PBR material failed (RH-68543)
  • SDK: Divider did not work in vertical orientation (RH-68546)
  • SDK: RhinoCommon: Intersection.CurveLine returned all wrong ParameterB values (RH-68486)
  • Sweep2: Regression between 7.13 and 7.14 (RH-68379)
  • Trim: Non-trimmable lines selected by SelBrush or SelFence causing infinite loop (RH-68721)
Crashes Fixed:
  • Rendering: Materials: rdk!CRhRdkMaterial::UpdateDocumentTables – Access Denied (RH-68577)
  • What: File with invalid polyline curve crashed Rhino (RH-68544)
Enhancements:
  • ExtrudeSubD: Made settings sticky between sessions (also in ExtrudeMesh) (RH-66247)
Features Added:
  • Eto: GridView/TreeGridView could not get or specify order of columns (RH-58995)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Exposed additional Brep.MergeCoplanarFaces overrides (RH-68618)
    • Exposed ProxyBrepSubD information (RH-68365)
Mac-Only Changes
Bugs Fixed:
  • BlendSrf: Sliders lost control on the surface (RH-68426)
  • Rendering: Materials: Thumbnails did not appear on Mac (RH-68679)
  • TextObject: Fonts did not appear properly on Mac (RH-68539)
Bugs Fixed:
  • 4View: Did not redraw viewports until view manipulation (RH-67440)
  • Annotation: Properties panel slowed down selecting annotation text (RH-68432)
  • Annotation: Text: Dialog extended to full screen width (RH-68004)
Rhino 7 Service Release 19 Hot Fix 1 for Windows and Mac (7.19.22180) is now available
Bugs Fixed:
  • Licensing: Cloud Zoo: Rhino gets logged out when a third-party plug-in tries to get a license from Cloud Zoo (RH-69179)
Rhino 7 Service Release 20 for Windows and Mac (7.20.22193) is now available
Bugs Fixed:
  • DimArea: Reported a negative value in a specific case (RH-68956)
  • ExtractSubCrv: Reported too many messages in command-line history (RH-68919)
  • Gumball: Extrude handles did not show for sub-objects until Reflect was updated or removed (RH-68603)
  • GumballAlignment: Default did not update (RH-68735)
  • Lights: Dragging intensity spinner and releasing left mouse button on color box incorrectly popped up select color dialog (RH-68625)
  • Match: Curvature continuity changed wrong end of curve (RH-68826)
  • NamedSelections: Adding selection sets did not trigger saving file prompt if no other changes were made in the model (RH-68727)
  • Picture: Displayed the old bitmap even after deleted (RH-68637)
  • Rendering: Cycles Viewport: Skylight did not properly turn off (RH-69072)
  • Scale1D: Scaling block insertion points incorrectly scaled block geometries (RH-64983)
  • Surface-surface intersection: Overlapping detection was much slower in V7 (RH-68720)
  • ToNURBS: Failed when SubD faces exceeded 30k (RH-62025)
  • Undo: Only one Undo was possible if Max undo memory was set to 4096 MB (RH-47940)
Crashes Fixed:
  • Layout: Right-clicking a field in the Layouts panel caused a crash (RH-68840)
Enhancements:
  • TextField: CurveLength, Area, and Volume pay attention to annotation linear resolution instead of model unit display precision (RH-68638)
Regressions Fixed:
  • SDK: RhinoCommon: Intersections.CurveLine sometimes returned null (RH-69329)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Added IRhRdkContents::SelectContent() (RH-68627)
    • Exposed ON_Geometry::DataCRC (RH-68961)
    • Exposed CRhinoEventWatcher::OnUnitsChangedWithScaling (RH-68860)
Tasks Completed:
  • RPC: Plug-in is removed from Rhino installer (available for download from Package Manager) (RH-69251)
Mac-Only Changes
Bugs Fixed:
  • Block: Editing block definition properties did not flag file being modified (RH-68825)
  • Grasshopper: Status bar was missing (RH-68957)
  • Layer: Could not turn off multiple selected layers at once in Layout and Detail (RH-58612)
Bugs Fixed:
  • Annotation: Styles: Editing suffix of length units locked up (RH-68617)
  • LoadPlugin: Some plug-ins failed to initialize after installing the latest SRC (RH-69016)
Rhino 7 Service Release 21 for Windows and Mac (7.21.22208) is now available
Bugs Fixed:
  • File IO: Identical materials with different names in OBJ were imported as one material (RH-62963)
  • Match: Selection highlight glitch (RH-69296)
  • Project: SubD was duplicated when all selected vertices missing the target object (RH-69098)
  • RefitTrim: New edge did not fit precisely to the edge trimmed by an isocurve (RH-69009)
  • Rendering: Post Effect: Glow control broken when adding new colors (RH-68298)
  • Rendering: Textures: Hiding objects deleted baked textures (RH-69272)
  • SetPt: Dialog missing title (RH-69244)
  • ViewCaptureToFile: Produced images with lighter colors than being seen in viewport (RH-67649)
Enhancements:
  • LayerStateManager: Restored layer state can be undone (RH-69031)
Regressions Fixed:
  • DupBorder: Did not duplicate linear edges as degree 1 line segments (RH-68994)
SDK Enhancement:
  • SDK: RhinoCommon: Added TextObject.GetTextCorners method (RH-69094)
Mac-Only Changes
Bugs Fixed:
  • Rendering: Problems with size and ESC button in Render window on Mac (RH-69239)
Bugs Fixed:
  • AttachGHSData: Components had duplicate names (RH-56670)
Rhino 7 Service Release 22 for Windows and Mac (7.22.22255) is now available
Bugs Fixed:
  • Distance: Incorrect negative (RH-69506)
  • Rendering: Pressing ESC did not ask to cancel rendering and close Render window (RH-69004)
  • Rendering: Cycles: Environment and Material thumbnails were black for Nvidia cards (RH-70067)
Regressions Fixed:
  • Rendering: Cycles: OptiX device failed to render (RH-69807)
  • SDK: RhinoCommon: Intersection.RayShoot bug (RH-69588)
Mac-Only Changes
Crashes Fixed:
  • SDK: System.Drawing.Icon.Dispose() did not check for null (RH-69648)
Bugs Fixed:
  • Installer: MicroScribe plug-in was loaded at first run after updating Rhino (RH-69802)
  • Licensing and Validation: False positive when checking for server environment (RH-69722)
Rhino 7 Service Release 23 for Windows and Mac (7.23.22282) is now available
Bugs Fixed:
  • Grasshopper: Contour component did not work properly (RH-70299)
  • Layout: Layouts panel not updating when sorting layouts via code (RH-69837)
  • Rendering: Materials: Setting programmatic PBR property did not show in GUI (RH-69463)
  • TextField: Area function might return a negative value (RH-69998)
  • UVEditor: Showed old custom mapping mesh (RH-69757)
Enhancements:
  • SDK: Added C++ functions behind BrepEdgeList.RemoveNakedMicroEdges (RH-69805)
  • SDK: RhinoCommon:
    • Added new SubD.PackFaces method (RH-69761)
    • Added GetPoint.NumberPreview (RH-69831)
  • Splash and About: Added "Getting Started Tutorials" button on splash screen to open LEARN page on Rhino website (RH-69959)
Features Added:
  • Rendering: Cycles: Uses the new PTX CUDA kernels instead of CUBINs (RH-69652)
Regressions Fixed:
  • File IO: Text did not import from some PDF files (RH-69775)
  • ViewCaptureToClipboard: Materials became transparent (RH-70307)
Rhino 7 Service Release 24 for Windows and Mac (7.24.22308) is now available
Bugs Fixed:
  • Display: Thumbnail environment rendering mismatching between OpenGL and RhinoRender (RH-69077)
  • DraftAngleAnalysis: Mid value might be incorrect after a lower value was entered to upper value field (blue) (RH-70246)
  • DupBorder: Too explodeable (RH-71030)
  • PackageManager: Package Manager does not show all packages (RH-71156)
  • RDK:
    • Render import conflict resolution failed when inserting blocks (RH-70529)
    • Texture mapping offset lock button did not work. (RH-70515)
  • Rendering: Cycles: Environment did not rotate in Raytraced mode (RH-70634)
Mac-Only Changes
Regressions Fixed:
  • Display: Objects did not shade in shaded display modes (RH-70627)
Rhino 7 Service Release 25 for Windows and Mac (7.25.22326) is now available
Bugs Fixed:
  • GetObject: IPlane and SubCrv options were incorrectly made always available (RH-70946)
  • MoveUVNOn: SubD control points edited by MoveUVN did not apply (RH-49848)
  • Rotate3D: Int object snap did not find intersection between feedback arc and another curve (RH-71247)
  • SDK: DisplayBitmap reported incorrect height (RH-71155)
Enhancements:
  • SDK: RhinoCommon: Exposed ON_NurbsCurve::ConvertSpanToBezier (RH-71249)
SDK Enhancement:
  • SDK: Allows CRhCurveBoolean not to print error messages (RH-70774)
Mac-Only Changes
Bugs Fixed:
  • RDK: Resample texture input problem / bugs (RH-70945)
Bugs Fixed:
  • Annotation: Text: Missing font detection did not recognize localized font names (RH-59268)
  • Purge: Did not remove unused annotation style (RH-71104)
  • SDK: GhPython: Copy "Hint" of neighboring inputs or outputs (RH-54143)
Rhino 7 Service Release 26 for Windows and Mac (7.26.23009) is now available
Bugs Fixed:
  • Offset: Bad curves were created in V7 and V8, but not in V5 (RH-72102)
  • RDK:
    • Objects temporarily lost materials (RH-71854)
    • Strange colours in render content preview thumbnails (RH-71473)
  • Rendering: Ground Plane settings did not undo (RH-71999)
Enhancements:
  • SDK: RhinoCommon: Exposed ON_BrepVertex::m_tolerance (RH-71671)
Rhino 7 Service Release 27 for Windows and Mac (7.27.23032) is now available
Bugs Fixed:
  • Display: "Show grid on top of objects" setting did not work (RH-44760)
SDK Enhancement:
  • SDK: RhinoCommon: Exposed CRhinoPrintInfo::m_textdot_size (RH-72325)
Bugs Fixed:
  • Display: Cycles rendered a blank viewport with OpenGL 2.1 (RH-71941)
Rhino 7 Service Release 28 for Windows and Mac (7.28.23058) is now available
Bugs Fixed:
  • Angle: Incorrect with some edges (RH-73003)
  • File IO:
    • Leader exported to DWG pointed to a wrong place (RH-72074)
    • Updated Datakit libs to 2023.1 that supports reading SolidWorks 2023 files (RH-70604)
  • GumballAlignment: Axes directions of Gumball (align to object), UVN, MoveUVN were incorrect for control points on SubD-friendly curves (RH-72629)
  • Help: BooleanIntersection needs to be added to the list on History’s Help page. (RH-72462)
  • Licensing and Validation: License manager dialog hidden behind all other open windows (RH-71806)
  • RDK: "Properties: Materials" panel did not show options (RH-72737)
  • Rendering: Materials: Layers in Choose Layers dialog did not list in alphabetical order (RH-72595)
  • Revolve: History shifted the axis (RH-65682)
  • SDK: RhinoCommon: rs.ObjectColor() always returned A (transparency) value as 255 (RH-72572)
  • Sun: Daylight saving in Eto dialog did not work properly (RH-73045)
  • UDT: Flowed object and naked edges (RH-42841)
Bugs Fixed:
  • Notes: Text in Notes panel was all selected when Rhino window regaining focus (RH-65292)
Rhino 7 Service Release 29 for Windows and Mac (7.29.23107) is now available
Bugs Fixed:
  • BlendEdge: Failed when chain-selecting edges with double-clicking (RH-73662)
  • CrvDeviation: RhinoCommon SDK: Curve.GetDistancesBetweenCurves method does not work if curves do not share a similar direction (RH-73988)
  • Rendering: Reflection on back faces looked different from front faces (RH-72717)
  • Select: DoubleClick + Shift + CTRL Control Cage caused a hang (RH-73884)
Enhancements:
  • ShowDir: Direction color change did not persistent through sessions (RH-73171)
Regressions Fixed:
  • ExtractAnalysisMesh: Did not save vertex colors from Draft Angle Analysis (RH-73089)
  • File IO: Nested blocks in DWG read incorrect in Rhino (RH-72439)
  • SDK: RhinoCommon: Bug of Curve.OffsetOnSurface (RH-73651)
Bugs Fixed:
Rhino 7 Service Release 30 for Windows and Mac (7.30.23163) is now available
Bugs Fixed:
  • Maxwell Render Settings are not visible when I switch the Current Renderer (RH-68628)
  • File IO: Problems of exporting leaders to DWG (RH-73335)
  • Grasshopper: "Mesh Brep" component not making closed mesh from closed Brep (RH-74187)
  • Join: Edge handling in Join: Difference between Rhino 6 and later (RH-74792)
  • SDK: RhinoCommon: Layer naming using Rhino3dm (RH-75120)
  • SimplifyCrv:
  • UDT: CageEdit: Fails on polyline (RH-75062)
Enhancements:
  • SDK: ON_PolyCurve trim returns polycurves. (RH-38502)
SDK Enhancement:
  • SDK: RhinoCommon: Add ReplayHistoryResult.UpdateToInstanceReferenceGeometry (RH-74822)
Rhino 7 Service Release 32 for Windows and Mac (7.32.23215) is now available
Bugs Fixed:
  • BoxEdit: The panel causes a delay in History updates (RH-71250)
  • ExtrudeCrv: Output=SubD broken for closed polylines (RH-76104)
  • File IO: Import multipage PDF not scriptable (RH-75099)
  • Localization: Tools (menu)>Object Snap>On Object>Persistent on … object snaps are missing the underscore. (RH-76079)
  • ProjectToCPlane: ProjectToCplane: Fails on Edge (RH-75703)
  • SDK: RhinoCommon:
    • Curve.Trim bug (RH-75627)
    • Polyline.IsClosed should call ON_Polyline::IsClosed (RH-75351)
  • TextField: Area Field Override Incorrectly Applied Annotation Style Unit (RH-75384)
SDK Enhancement:
  • SDK: RhinoCommon: Added Radial dimension to a File3dmObjectTable (RH-75418)
Tasks Completed:
  • Help: V7 offline help is made to install for all users (RH-76056)
Rhino 7 Service Release 32 (Hot Fix 1) for Windows and Mac (7.32.23221) is now available
Bugs Fixed:
  • C++ SDK Broken in Rhino 7.32 (RH-76240).
Rhino 7 Service Release 33 for Windows and Mac (7.33.23248) is now available
Bugs Fixed:
  • SDK: Rhino C++ SDK break in CRhinoFileUtilities::GetRhinoApplicationDataFolder (RH-76240)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Allows access to displayed order of layers as shown in Layers panel. (RH-76087)
    • Added “Zoom Window” function (RH-75756)
Rhino 7 Service Release 34 for Windows and Mac (7.34.23267) is now available
Bugs Fixed:
  • CopyHole: UseLastDistance prevents command from finishing (RH-76911)
