Rhino 7 Service Release Available
Rhino 7 Service Release 17 for Windows and Mac (7.17.22102) is now available
Rhino will automatically update, unless updates are disabled.
Download the latest service release now…
Bugs Fixed:
  • MeshCylinder: Vertex normals of base cap pointed inwards (RH-67428)
  • PackageManager: Scriptable command was not pre-populating search (RH-67805)
  • SDK: RhinoScript: MeshMeshIntersection rhinoscript (VbScript) tolerance problem (RH-67504)
  • SpaceMouse: 'Auto Rotation Center' moved target very close to camera and caused objects far away to be clipped (RH-67392)
  • SubD: Edge sector coefficient evaluation was wrong for corner vertices (RH-67377)
Enhancements:
  • Display: Shows "Enable GPU detection" button when initializing of CUDA fails and GPU is disabled (RH-67747)
  • RecordAnimation: Supports creating animation from Raytraced viewport (RH-57903)
SDK Enhancement:
  • RDK: Added C++ and C# API for creating an OCS type ON_TextureMapping (RH-67578)
Tasks Completed:
  • Help: Rewrite the help and other docs for commands using the mesh detailed options dialog (RH-66828)
Mac-Only Changes
Bugs Fixed:
  • DocumentProperties: Changing units did not prompt for scaling the model (RH-67851)
  • Eto: Occasional crash in plugins panel on Mac (RH-67444)
  • Update System: Updating to 7.17 failed on MacOS (RH-67833)
Crashes Fixed:
  • ReduceMesh: Crashed on MacOS 12.3 (RH-67912)
Windows-Only Changes
Bugs Fixed:
  • Toolbar: Saving RUI file failed with menu items (RH-67926)
Regressions Fixed:
  • Annotation: Dot: Unicode Symbols (L Sep / Line Separator) visible in German Rhino (RH-67411)
SDK Enhancement:
  • SDK: 3dm export allows specifying a different unit system (RH-67485)
