I am a rhino 6 commercial user, and I downloaded Rhino7 evaluation to try and see if my workflow is impacted by the upgrade. I plan on using subD at a later point but right now I’m mainly doing workday tasks I normally would do in Rhino 6.
The results have been a little less then expected…
The application seems to still think it is rhino 6 in windows even though rhino 7 has an icon (see task bar)
when doing a render even with basic settings the renderer seems to clock running like (some small number of) 50 passes … Basic renders in rhino 6 take a few seconds. 7 takes minutes. I keep turning down the settings and it’s still very slow… post effects like annotations and edge curves seem to make it even slower.
I also tried adding an effect after the render … and it works but there is a curious note about post effect UI I don’t fully understand (and I’m sure others here will quickly fill me in)
Union/difference commands “seems” slower (have not hard tested this but in general it seems slower)
STL export wizard second screen tends to pop behind the rhino session in windows, also exporting seems a bit slower
I’m surprised that the upgrade fee has more then tripled -or doubled at “special” price but i assume that was necessary for reasons and i still appreciate the fixed price versus subscription model. Being 2020 was the dumpster fire it was, I could not afford this new higher upgrade price so i punted the football and downloaded the eval copy to get me through to Q1 2021. What confuses me is the no upgrade to evaluation copy notice. If I downloaded the evaluation copy as funds were tight as opposed to directly upgrading my Rhino 6 commercial do I need to uninstall the evaluation copy before I can upgrade rhino 6?
Thanks!
Brian Carnes
Sea Dog Game Studios
Dublin Ohio USA
