Rhino 7 Not Using Nvidia 5070 Ti Laptop GPU
I’ve been having a tremendously difficult time getting Rhino 7 to recognize and use my GPU. This has resulted in odd rendered view behavior such as this:
I have tried adjusting the NVIDIA Control Panel settings for OpenGL, changing the Windows settings for graphics, fully uninstalling Nvidia drivers with DDU and reinstalling latest studio driver versions. Additionally, I double checked and Rhino is up to date. Any help is greatly appreciated.
Here is my system info:
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31Gb)
Computer platform: LAPTOP - Plugged in [30% battery remaining]
Primary display and OpenGL: Microsoft Basic Display Adapter (Intel) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y). OpenGL Ver: 1.1.0
Integrated graphics device with 1 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
NVIDIA GeForce RTX 5070 Ti Laptop GPU (NVidia) Memory: 12GB, Driver date: 12-30-2025 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 4.14.0.668
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
Nvidia Control Panel Settings:
Rhino settings:
Windows Settings:
Device Manager:
It looks like you have the right settings. On occasion these can be troublesome.
Lets do a clean install of the nvidia drivers (The January windows update has been problematic in this regard)
  1. Run the driver installer again
  2. choose custom
  3. check the ‘clean driver install’ option
There are apps on certain computers that can override your settings as well.
Lenovo - Lenovo Vantage Lenovo gaming laptops use Lenovo Vantage software, which includes a “Hybrid Mode” switch on the right-hand side of the interface. When Hybrid mode is enabled, Optimus is on; when Hybrid mode is disabled, Optimus is turned off, requiring a reboot for changes to take effect Jarrod’s Tech
ASUS - Armoury Crate ASUS laptops use Armoury Crate, which includes GPU Mode settings that allow switching between different power-saving modes including Eco Mode, Standard, and Ultimate (discrete GPU) modes, with MUX Switch functionality integrated after version 5.2.12 ASUSAsus
MSI - Dragon Center / MSI Center MSI laptops use Dragon Center (older models) or MSI Center (newer models), which includes a GPU Switch option to toggle between MSHybrid Graphics Mode and Discrete Graphics Mode MSIMSI USA
HP - OMEN Gaming Hub HP OMEN and Victus laptops feature the OMEN Gaming Hub with a Graphics Switcher that allows users to toggle between Hybrid mode and Discrete mode HpHp
Acer - Predator Sense Acer Predator gaming laptops use Predator Sense software, which includes a “Discrete GPU only” option accessible through the settings (cog icon) Jarrod’s Tech
Razer - Synapse Razer Blade laptops use Razer Synapse (version 3 or 4), which includes GPU Mode settings under the Performance tab to switch between integrated and dedicated graphics Razer SupportRazer Support
Gigabyte/AORUS - Control Center Gigabyte AORUS laptops feature the AORUS Graphics Switch in the AORUS Control Center (or GIGABYTE Control Center), allowing users to switch between discrete NVIDIA graphics and integrated Intel graphics using MUX switch technology GIGABYTEVortez
Dell Some Dell gaming laptops (like the G15 5515) require switching through BIOS rather than software, accessed by pressing F2 during boot and navigating to the Advanced tab to toggle “Enable Hybrid graphics” Jarrod’s Tech
Alienware Alienware laptops typically don’t have front-end software for MUX switching and require BIOS configuration, accessed during boot by pressing F2
That doesn’t sound good
I was just about to type this but this option is important it switches between the gpus
Okay, thank you so much for the help. It turned out that my Intel Drivers were out of date in general. I installed the driver updater software, which I was not used to as I remember older Intel cpu’s not having a proper installer app, but now it’s fixed! I installed the “Intel Arc Graphics - Windows” located here https://www.intel.com/content/www/us/en/products/sku/242293/intel-core-ultra-9-processor-275hx-36m-cache-up-to-5-40-ghz/downloads.html
Here is my new system info for those in the future.
Computer platform: LAPTOP - Plugged in [67% battery remaining]
Primary display: Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 1-16-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
    Primary OpenGL: NVIDIA GeForce RTX 5070 Ti Laptop GPU (NVidia) Memory: 12GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
Z-Buffer depth: 24 bits
Total Video Memory: 12227 MB
