I’m using Rhino 7 Evaluation version 7.4.21067.13001, 2021-03-08 update.
There’s a bug in Move command. I select an object, hit Move and type-in the distance to move, and it seems to miss it for a couple of times, it randomly gets another value. It works after a couple of tries.
Hi - That’s a known issue with 7.4 that was fixed in 7.5. You can install the current release candidate by changing the update frequency in the Rhino options.
