I wanted to ask where I do change the Near Clipping Plane settings for Rendered View. In Shaded View the geometry is not cut, meanwhile in Rendered View there seems to be some Near Clipping Plane setting on… I do not know where to change that…
You can’t directly edit the clipping distance values for the camera. Try turning on the Ground plane in the Rendering panel in this case. That should increase the range.
Hi Brian, the opposite works. The ground plane was turned on and when I switch it off it solves my problem and I have no cut off from the near clipping plane.
Thanks a lot!
