I’ve been having some issues trying to render using the legacy Rhino render. It seems to think that the render is completed while leaving some small non-rendered horizontal lines on the rendering. I’ve attached photos to show what I’m talking about. After scouring the internet, I can’t seem to find anyone else who has experienced the same problem, although anecdotally, it’s happened to one of my classmates. All of these renders have these types of artifacts and I’d love to figure out a way to see if there’s something I can do to make it stop happening. I’ve also included a screenshot of the finalized render screen in case there’s something I’m missing or some setting that I need to double check.
For context, because I imported this model from sketchup, I don’t have a way of closing the geometry which gives the non-legacy Rhino Render some issues, especially as I’m using a clipping plane here to create a plan view. Legacy Rhino Render seems to give the best result except for these annoying lines that appear to be parts of the image that are not completely rendered, even though the software says the render is complete.
If anyone has experienced this issue before, or perhaps has found a solution, I’d love to hear it.
Thank you!
[EDIT: I forgot to include that I’m using the Intel Denoiser plugin, however, this issue has persisted before installing it and does not appear to be related]
Computer/software information:
Rhino: Version 7 (7.23.22282.13002, 2022-10-09)
OS: MacOS Monterey 12.6
Computer: Macbook Pro 14 in. 2021
Processor: M1 Pro chip
Memory: 16 GB
Apple macOS Version 12.6 (Build 21G115) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,3
Language: en-US (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Pro
Color LCD (1512 x 982 @ 120.00Hz)
/Users/natesmith/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
/Users/natesmith/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.4/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
Can you post the 3dm or email it to tech@mcneel.com with a link back to this forum post? I would like to try and reproduce this issue but at the same time, I bet you could get the same or better result using the v7 Rhino Renderer instead. I would also look at ways to close the objects so the clipping intersection is solid.
I’ll email them, thanks for the advice! Posting the .3dm in this comment as well
[EDIT: the open geometry is unfortunately a side effect of this being an early project I created in sketchup that I don’t have a lot of time to remodel in closed form using Rhino, but I’ll see if I can find some time soon. Many thanks again for the advice!] program only.3dm (10.8 MB)
Thanks for the file… I haven’t been able to reproduce this on Mac or Windows Rhino 7 using the Legacy Rhino Render. The file may not be exactly the same though as it didn’t have a clipping plane in it or the Sun on. I added those but still can’t get it to happen.
So I don’t have much to suggest yet unfortunately other than using the newer Rhino Render which yields a different Sun shadow which doesn’t pay attention to the clipping plane. I filed that as https://mcneel.myjetbrains.com/youtrack/issue/RH-70997 though. You’d have to use Wirecut on the model and then render that to get the same shadow. I’d also use the Intel denoiser after around 150-200 samples.
