Problems with Rhino render and Legacy Rhino render
Hello everyone,
I am running into an issue when rendering with Rhino render. No matter how good the resolution and the quality are I cannot get smooth diagonal edges. I’ve tried updating the drivers, switching from gpu to cpu, different settings, anti-aliasing, reinstalling the Rhino… nothing has worked yet Pictures attached:
When rendering with Legacy Render, no matter how I adjust the sun settings the shadow is always cast in the same direction.
Thanks!
System info below:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 9-5-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 561.09
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-5-2024
Driver Version: 32.0.15.6109
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\janvr\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
Jagged lines like that in Rhino Render is typical for models that are far away from world origin (w0, aka 0,0,0).
Share a file if you want more than just guesses.
Many thanks! It seems to work for Rhino render. Legacy still can not render sun shadows in the correct direction. Please find the file attached:
buildings.3dm (2.2 MB)
I don’t think there will be any changes made to the Legacy Renderer, but to be sure I’ll log it anyway: RH-84056 Legacy Renderer doesn’t render sun correctly
Rhino Render is the preferred render engine.
Many thanks!!
