Rhino 7 - How do you print multiple layouts on one PDF?
I am trying to print multiple layouts on one PDF with all the measurements. The annoying thing is when I click on export as PDF the ‘multiple layouts’ option is greyed out and cannot be selected. Can anyone explain how I can do this? I am using the MAC version.
Thanks, Josh
Hi Joshua -
I’m not sure where you click on “export as PDF”. To create a single PDF file from multiple layouts on the Mac, go to a layout, run the ExportAll command (or, from the menu, pick File > Export), and select the PDF (pdf) file format at the bottom of that dialog. You should then be able to select the Multiple Layouts option.
If this procedure doesn’t work for you, please provide a simple 3dm file that shows this behavior on your system.
