Rhino 7 - Frozen Perspective Viewport
Hello, I am using Rhino 7 on a new Lenovo laptop connected to multiple monitors via a Dell D3100 universal dock. Often when the laptop sleeps, after waking it, the perspective viewport will be frozen. The other default views update fine with movement and zooming in the model.
Interestingly enough, if I disconnect the external monitors by unplugging the laptop from a dock, the perspective viewport on the laptop unfreezes and I can pan, zoom, and orbit normally. If I reconnect the dock/monitors, the perspective viewport continues to be frozen.
I’ve updated my graphics card with the latest drivers, performed all system updates, and done multiple restarts of the system as well as the graphics driver. Any idea as to what may be causing this issue? Prior to this new laptop, I used this same dock with a Dell laptop for 3-4 years without issue.
System Info
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 63Gb)
Computer platform: LAPTOP - Plugged in [78% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 6-30-2025 (M-D-Y).
External USB display device with 3 adapter port(s)
Windows Main Display attached to adapter port 0
Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA RTX PRO 1000 Blackwell Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-10-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.72
Integrated accelerated graphics device (shares primary device ports)
Video pass-through to primary display device
Secondary graphics devices.
External USB display device with 0 adapter port(s)
There are no monitors attached to this device. Laptop lid is probably closed
Intel(R) Arc™ Pro 140T GPU (32GB) (Intel) Memory: 2GB, Driver date: 4-3-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2026
Driver Version: 32.0.15.9672
Z-Buffer depth: 24 bits
Total Video Memory: 8151 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
I’d check and see if there is a new driver for your display link. Clearly there is something going on there if it works when it’s disconnected.
Excellent suggestion, I’ve updated the DisplayLink to the most recent driver.
great, are back up and rolling?
Well, I thought that had fixed it, but the perspective viewport is frozen after waking my laptop from sleep.
hmmm.. ok, it may be worth checking this article and following the steps that help sort hybrid machines.
we want to make sure that your machine is forced to the nvidia at all times. My guess is that there is some switching going on between the nvidia and the intel hd that is complicated by the dock. My gut tells me that forcing the machine to run on the nvidia at all times may help, but this is admittedly a WAG.
Out of the box, the graphics GPU preference was set to High Performance. I verified that Rhino lists the Nvidia GPU as the Primary OpenGL card.
I did amend some settings in the Nvidia control panel to prefer maximum performance and default to the Nvidia GPU. I’ll report back on how things go.
Update: the perspective viewport froze after waking from sleep with the steps recommended in the hybrid graphics thread.
if you run the 4view command does it reset the perspective view?
Does it freeze without the dock? Lets eliminate that as a variable.
DisplayLink doesn’t work like a normal video output — it has the GPU render the desktop, then compresses that framebuffer and pushes it over USB to the monitors. GPU-accelerated OpenGL surfaces (which is exactly what Rhino’s Perspective viewport is) are the weak spot. When the laptop sleeps, the OpenGL context is torn down and recreated on wake, and the DisplayLink virtual display often keeps showing the stale accelerated surface — so the shaded Perspective view “freezes” while the wireframe-ish parallel views recover on redraw. That also explains why unplugging the dock instantly fixes it: the viewport falls back to a real GPU output.
A few things to try, roughly in order:
  1. Move the Perspective viewport to the laptop’s built-in screen while the dock is connected. If it updates fine there but freezes on the docked monitors, that confirms it’s the DisplayLink path, not sleep/wake itself.
  2. Quick recovery test: after it freezes, switch that viewport’s display mode to Wireframe and back to Shaded (or maximize/restore it). If that “unsticks” it, we’ve confirmed a stale GL surface rather than a true hang.
  3. Bypass DisplayLink: plug a monitor directly into the laptop’s own HDMI/USB-C (DisplayPort-alt) port instead of the dock. That routes through the NVIDIA/Intel GPU natively. If the freeze disappears, the dock’s DisplayLink compression is the culprit — not the dock being connected per se.
  4. Power settings to stop the GPU/display context from being dropped: in the active power plan, disable USB selective suspend, set PCI Express → Link State Power Management to Off, and disable DisplayLink / monitor sleep aggressiveness. Also grab the latest Synaptics DisplayLink Manager app (separate from the in-box Windows driver).
  5. If you have access, try the same setup in Rhino 8 — its display pipeline handles device-loss and wake/reattach considerably better than 7.
The 4view command does reset the perspective view when the laptop is docked and the viewport has frozen! After using the command, if I unplug the laptop from the dock, Rhino works normally on the laptop screen. Reconnecting the dock, all four viewports freeze, however the 4view command restores functionality.
Japhy, I tested the laptop without the dock and it did not freeze when it slept. Interestingly enough, with Rhino on the laptop screen, unfrozen, connecting the dock resulted in every viewport freezing, except Left, on the laptop screen. The viewports remained frozen when I moved Rhino from the laptop to an external monitor connected to the dock. The 4view command was able to reset everything and make it function again.
Here are the results of the suggestions I’ve tried so far:
  1. The perspective view remained frozen when moving it between the docked monitors and the laptop screen.
  2. Changing the viewport display mode did not restore the views.
  3. Unplugging the dock restores functionality to the viewports. The viewports continued to work on an external monitor when plugged into the laptop directly (circumventing the dock). Oddly enough, the viewports won’t freeze if I have the laptop connected to the dock (dock connected to a monitor) and then an external monitor connected to the laptop through HDMI.
ok, so it’s clear there is something going on with the dock. If the 4view command gets you running again, that may be the workaround to allow this to be your set up. If that is unacceptable, you may want to try rhino 8, or look into purchasing a newer dock-
