Rhino 7 freezing with textures, materials, raytracing .. very random
Hi, I am having a random freezing problem sometines with textures, rendering, editing materials, etc. After freezing I have to force shut down my notebook. No way to close / reopen rhino. Just upgraded to rhino 7 but same happened in 6. No 3rd party plugins … sys info below.
Any help would be very appreciated.
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Educational, build 2021-05-07
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 5.9Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
Primary OpenGL: NVIDIA GeForce GT 540M (NVidia) Memory: 2GB, Driver date: 5-17-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 389.34
> Integrated accelerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-17-2018
Driver Version: 23.21.13.8934
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
update your drivers for your intel and your nvidia. Both of which are below our recommended spec of 4gb of vram. Even at it’s best this machine will struggle with gpu tasks. However, the driver updates will help.
intel updates here- (use the scanner tool) - https://downloadcenter.intel.com/
nvidia updates here -(use custom/ clean install) - Download Drivers | NVIDIA
Thanks Kyle, that is strange as it was working fine until going from win 7 to win 10.
At the moment it is freezing while navigating inside the render tab, ground plane tab or even a color wheel tab (are these gpu related?) … not running raytrace mode at the moment.
win 10 is more gpu intensive Afaik… someone smarter may have better info. However the bigger issue is most likely the older graphics instructions of your old drivers.
In Rhino 7 all thumbnails are rendered essentially with Raytraced. In Tools > Options > Cycles ensure you are using CPU (it should, but just to verify). Other than that Raytraced is now on CPU. That is probably also very slow if your machine has still a GT 540M, which is wrt rendering prehistoric.
