I have a simple surface on which I have mapped a PBR texture. When the surface is selected, the texture shows correctly in rendered view. When I deselect the object, the texture is removed and the surface appears white. The same file works as expected in Rhino 7 for Windows.
I’ll upload the file separately as it’s quite large.
System info:
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.17002, Git hash:master @ b109c0eb42133053936614c484cb870a02a53b49)
License type: Commercial, build 2021-01-12
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.1 (Build 20C69) (Physical RAM: 32Gb)
Mac Model Identifier: iMac15,1
Language: en-AU (MacOS default)
AMD Radeon R9 M295X OpenGL Engine (OpenGL ver:4.1 ATI-4.2.13)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon R9 M295X
Displays: iMac (217dpi 2x)
Graphics processors
AMD Radeon R9 M295X (4 GB)
iMac (2560 x 1440)
USB devices
Seagate: Expansion
VIA Labs, Inc. : USB3.0 Hub
TOSHIBA: External USB 3.0
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
VIA Labs, Inc. : USB2.0 Hub
EATON: 5E
HLDS Inc.: SLIM Portable Blu-ray Drive
Bluetooth devices
Broadcom: Mighty Mouse
Broadcom: Apple Wireless Keyboard
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.2.21012.17002
