I’ve been running into an issue where I copy paste objects from one rhino window to the other and they show up blue instead of textured/colored (as they were in the original rhino window) This happens to some objects and not others at random. When I close & reopen rhino sometimes the objects show correct textures and sometime they don’t. Is this a bug??
Thanks!
Hello - Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR4 2021-3-19 (Rhino 7, 7.4.21078.01002, Git hash:master @ a432d22ab7f0f7b53d157d578278070c8bf6eff4)
License type: Commercial, build 2021-03-19
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G8022) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,3
Language: en-US (MacOS default)
AMD Radeon Pro Vega 20 OpenGL Engine (OpenGL ver:4.1 ATI-2.11.23)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: Radeon Pro Vega 20
Displays: Color LCD (258dpi 2x), U28D590 (160dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro Vega 20 (4 GB)
Color LCD (1680 x 1050)
U28D590 (1920 x 1080 @ 30 Hz)
USB devices
Logitech: USB Optical Mouse
USB Storage: USB Storage
VIA Labs, Inc. : USB Billboard Device
Realtek: USB 10/100/1000 LAN
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.verdasys.dgagent (0050.64.7) 25B3F5B5-D134-3A5E-8560-A175723EE202
com.cisco.kext.acsock (4.9.40) 111600D2-22B9-302C-A9DE-C4D74C433469
com.crowdstrike.sensor (125.05) 0D5F5D2F-6F14-36C9-8E95-077B2B70FE78
Third party plugins
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.4.21078.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.4.21078.1002
Hello - if your mac supports it, I would update to a newer mac OS and see if that works any better - it looks like you are on Mojave, which is ‘old’ now.
