Rhino 7 Failed to fetch packages from source(s)
I’m coming up against an error when attempting to load the package manager in Rhino 7 (see image).
Here is the my SystemInfo
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Educational, build 2023-01-09
License details: Stand-Alone
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [88% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 2-1-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.69
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-1-2022
Driver Version: 30.0.15.1169
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Hi Natnaree -
You’ll need to make sure that the firewall on your machine or on the network that you are on does not block access to https://yak.rhino3d.com.
Its working! Thank you so much.
ITS SHOWING THE SAME PROBLEM FOR ME TOO, HOW DID U MANAGE TO IINSTAL IT
hi @aleena_nizami as mentioned, this needs to be done in your firewall settings.
Hello, I’ve tried disabling my firewall and restarting rhino and my device, but it’s still showing me the same thumbnail error. Any other tips? Thanks!
Please don’t double-post, and certainly not triple-post…
Hi, I only face the same issue.
Rhino 7 SR1 2020-10-25 (Rhino 7, 7.1.20299.23101, Git hash:master @ 8d9ce31398d29589acec390d2167dc68806d5b79)
License type: Commercia, build 2020-10-25
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Hybrid graphics system.
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.76
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-1-2024
Driver Version: 31.0.15.5176
Total Video Memory: 8188 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20299.23101
That’s correct, you are also using a cracked version of a very old Rhino 7 service release.
Hi. I’ve encountered this problem too, and it turns out the solution is very simple. I only want to install weaverbird but can’t access the rhino package manager. The solution is, I open my “windows defender firewall with advanced security”, and in the “inbound rules” I select all the “yak.exe” and disable rule. Then I go to the “outbound rules” and select all the “rhino.exe” and “yak.exe” and also “disable rule” to both. After that I can open the package manager in rhino and search and install weaverbird. After installing I enable rule to both the inbound and outbound rules of the yak.exe and rhino.exe for security (basically return to the previous setting). Hope this helps!
