Failure to fetch package manager server/folder
Hey guys,
I am trying to update a plugin (Hobs), but my Packager Manager is not working. I reinstalled Rhino but I get the same error. Tried to find a way to change that address folder that the PM is trying to access, but I cannot find it in Rhino.
I appreciate your help!
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hey @wim! Here we go:
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09001, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Commercial, build 2021-10-20
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 80Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-24-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Hej -
Thanks.
Go to the Rhino Options > Advanced page and type PackageManager in the search field.
Double-clicking on the value should pop up a dialog with a Set to Default button. Does using that one help?
Solved, @wim
This was the previous setting:
Hi Abdallah -
Hi Abdallah -
I was afraid of that. You are running a cracked version of Rhino 7.1. We’re on 7.23 now.
Hi, I have the same problem as OP. Im trying to install PanelingTools addon and Im getting similar error. Solution “Set to Default” did not help. The address in manager is “https://yak.rhino3d.com”.
Ill appreciate any help. Thanks!
Here is my system info:
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03001, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: Evaluation, build 2023-04-17
Expires on: 2023-07-17
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 9-18-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 411.63
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-9-2019 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-18-2018
Driver Version: 24.21.14.1163
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.29.23107.3001
Hi Alexander -
Have you tried to temporarily disable the firewall on your machine or on the network to make sure that your access to https://yak.rhino3d.com isn’t blocked?
Hi Wim, thanks for the tip! Looks like I will have to check with our IT about that.
While you’re at it, ask your IT crew to update your GPU drivers.
Hi John, indeed :man_facepalming:, but I guess thats a company feature unfortunately.
@wim The problem was fixed by turning off vpn :slight_smile:
Hi there, I have the same problem to fetch the package manager server:
Appreciate any commend and holp:)
here is my system info:
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: tion, build 2020-12-08
License details: Stand-Alone
Windows 10.0.22621 SR0.0 or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 532.09
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-2-2023
Driver Version: 31.0.15.3209
Total Video Memory: 4 GB
C:\Users\danie\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
You are running a cracked version of a very old Service Release of Rhino 7…
Hello, I’m having the same trouble. I can’t open my package manager and the source/value is already yak.rhino3d.com. I’ve also disabled my firewall. Here’s my systeminfo if you need to evaluate it, Thank you…
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Corporate, build 2022-07-27
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [81% battery remaining] ~57 minutes left
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.45
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 6-26-2023
Driver Version: 31.0.15.3645
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.2.1.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
That’s correct, you are also using a cracked version of a very old Rhino 7 service release.
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, build 2023-11-21
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 48Gb)
.NET Framework 4.8.9261.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 5-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.44
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-7-2024
Driver Version: 31.0.15.5244
Total Video Memory: 12 GB
C:\Users\Server\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Lumion-LiveSync-for-Rhino\3.60.65\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.140\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.140.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.40.3\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.40.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
Hi, I’m having the same problem cannot open package manager.
I checked the website too
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Evaluation, build 2024-09-10
Expires on: 2024-12-02
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
What should i do?
@wim
Hi, I’m having the same problem cannot open package manager at Rhino 8. I’ve tried disable the adblocker but it still doesn’t work.
