It says
The file writing plug-in failed
tried to disabled and enabled it but did not work…
any suggestion? do i need to reinstall rhino 7?
It says
Hello- please run the SystemInfo command in Rhino and posty the results here.
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-3-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 10-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 545.84
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-11-2023
Driver Version: 31.0.15.4584
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.1.0
C:\Users\austi\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23298.1547
C:\Users\austi\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.2\Substance.Win.rhp “SubstanceImporter” 2.0.2.0
C:\Users\austi\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
@austinaddress0211 does this fail if you export just a rectangle or circle? If not, please post a file that causes the failure, or send to tech@mcneel.com, with a link back here in your comments.
it’s a full file… unfortunately i cant really post the file here as NDA was signed for my project. I’ll see if it happens with other shapes if it does I’ll send the file over
Another likely cause is a 3rd party plug-in.
In Rhino Options > Plug-ins . change the list filter at the top to ‘Plug-ins that do not ship with Rhino’.
Disable all of them.
Close and restart Rhino.
See if you can DWG export.
If DWG export works, enable them one by one, restart, DWG export, until you find the plug-ins that’s gumming up the works.
So, a simple thing like a polyline or arc does export without errors, is that correct?
seems like if i export just circle it’s fine.
same file i asked my collegue to export it they didnt have any trouble
Hello - In that case, I’d work with John Brock’s thought about plug-ins, above.
One more thing to look into is the naming of objects and the naming of layers.
It could be that a character is used that the exporter doesn’t like.
