Rhino 7 delete (Zoo) license file on upgrade
we are using Rhino 7 with Zoo license (30-user license, Educational). If we install update (new SR), the installer deletes lic file from c:\ProgramData\McNeel\Rhinoceros\6.0\License Manager\Licenses, so we need to specify the license on the first run of newly installed SR of Rhino 7.
Even if we specify the Zoo server in advanced settings of the installer.
Interestingly enough, it deletes only lic file of Rhino 7 and lic file of Rhino 6 keeps intact.
And Rhino 6 is not doing it.
We use classic Zoo server, not Cloud Zoo.
Stanislav Olivík
How are you installing Rhino 7?
Are you running the Rhino 7.3 installer?
Are you using the scripted deployment tools?:
https://wiki.mcneel.com/rhino/installingrhino/7
I was using Rhino 7.4 installer (Release Candidate) in normal (interactive) mode. It behaves like that from the first SR, but was not doing it when it was WIP or beta version. I have tried various SR on computers with both Rhino 6 and Rhino 7 installed, and with Rhino 7 only.
There is a similar topic from user, who uses script and have the same problem.
I contributed to that topic, screenshot from my installer is there.
Today I tried the latest RC version of SR4 (installer rhino_cs-cz_7.4.21054.09561.exe). Even without going to advanced settings, it deleted the license file when finishing installation.
rhino_install
By the way, maybe the lic file should be placed in c:\ProgramData\McNeel\Rhinoceros\7.0\License Manager\Licenses if it is Rhino 7.
I am also experiencing this problem, with Rhino 7.7.21160.05001.
I created an installation batch script to temporarily back-up the licence file (from "%ProgramData%\McNeel\Rhinoceros\6.0\License Manager\Licenses\"), then put it back after Rhino finishes installing, and that works.
But it would be good to see this problem resolved in future builds.
The problem persists, and I keep reporting it to the licensing and tech email addresses, but it apparently remains unresolved.
Most recently, I verified it again during the update from version 8.10 to 8.13!
During the installation of version 8.13 over the existing version 8.10, the registry string ‘server’ in the key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\McNeel\Rhinoceros\6.0\License Manager is deleted.
In my opinion, the registered license server should absolutely not be deleted during an update. It should remain untouched!
When will this annoying problem finally be resolved? It’s been going on for years!
Here are the steps performed (sample from a later update):
  1. Version 8.9 was installed with this command line:
    rhino_de-de_8.9.24194.18121.exe -package -passive -norestart LICENSE_METHOD=ZOO ZOO_SERVER=zoo-lizenz.uibk.ac.at SEND_STATISTICS=0 ENABLE_AUTOMATIC_UPDATES=1 INSTALL_DE=1 INSTALL_EN=1 EULA_AGREE=1
  2. Existing ‘server’ string in regsitry key → Start of Rhino 8.9:
  3. Check for Updates:
  4. Result of update check:
  5. Closing Rhino starts update dialog (‘server’ string still existing):
  6. Click on ‘Yes’ starts 8.10 installer:
    Note well! At about one-third of the installation, the string ‘server’ is then deleted!!!
Problem is fixed now (see Rhino deletes License Manager HKLM registry key during update - #4 by Lorenz_Lois_Winkler)
