Rhino 7 crash
Hi there!
It was like 2 weeks ago when my Rhino 7 started crashing all the time I used commands like Split, Boolean Difference, Boolean Union, Merge All Coplanar Faces, and a few more. By the moment, I used to repair the Rhino with the installer. Then, uninstalling it and finally installing it again. Also I ereased my Rhino 7 folder where I previusly installed the program. However, few days later I made this procedure, Rhino started failing over again. I´ve made this procedure quite few times yet but now It seems like this is now not working. Any help will be appreciated :smiling_face_with_tear:
Rhino 7 SR25 2022-11-14 (Rhino 7, 7.25.22318.11001, Git hash:master @ a2a1c814d0ef5b996d590f644b06538db31a77aa)
License type: Evaluación, build 2022-11-14
License details: Cloud Zoo
Expires on: 2023-01-28
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [75% battery remaining] ~37 minutes left
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 11-8-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.86
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-8-2022
Driver Version: 31.0.15.2686
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NRVNTools\1.2.0\NRVNTools.rhp “NRVNTools” 1.0.0.0
D:\Archivos de programa\Rhino 7 Custom Plugins\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Walkie\4.7.0\Walkie.rhp “Walkie” 4.7.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
D:\Archivos de programa\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Archivos de programa\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Archivos de programa\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Archivos de programa\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22318.11001
D:\Archivos de programa\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Archivos de programa\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
Hi @asda_asda_sd
First thing to do is to try and disable your third party plugins and restart Rhino to see if that helps.There was another report on the Walkie plugin some time ago, so start there :slight_smile:
HTH, Jakob
Thanks for your quick answer :smiley:
By now it´s working. I something goes wrong, i´ll write the problem i find. Thanks again! :smiley:
