Rhino will sometimes crash when launching the program after restarting the computer, and after opening rhino some minutes later a bsod appears. The bsod specifically seems to happen only after opening rhino, so I suspect it’s the culprit. It seems to happen regardless of what file I open, or it might be this file that’s causing the problem, I’m not sure.https://drive.google.com/file/d/1ZOdQkaBCvlvwkoB7ITvZG9p4zudUziuU/view?usp=sharing
BSOD stop code: UNEXPECTED KERNEL MODE TRAP
bugcheck: 0x0000007f (0x0000000000000008, 0xfffff8021168fe50, 0xffff9886dce18fd0, 0xfffff8020c50428d).
here’s some errors related to rhino I found on the windows event viewer.
Faulting application name: Rhino.exe, version: 7.19.22165.13001, time stamp: 0x62a90401
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1741, time stamp: 0xe9b4a91b
Exception code: 0xe0434352
Fault offset: 0x0000000000034fd9
Faulting process id: 0x5984
Faulting application start time: 0x01d88c9ae10e962f
Faulting application path: C:\Program Files\Rhino 7\System\Rhino.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: a46a0d90-c93a-4abf-8fb1-9a0e28d132d0
Faulting package full name:
Faulting package-relative application ID:
Application: Rhino.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException
at System.ThrowHelper.ThrowInvalidOperationException(System.ExceptionResource)
at A.c7df263a9b37fff7c89f4dfbfe038d49a.ce1cc06bc9fd9b41cdcda7103d008bbe3(c6d8c98e4398d53a828be90c2f7f5c9b1)
at A.c7df263a9b37fff7c89f4dfbfe038d49a+c6d8c98e4398d53a828be90c2f7f5c9b1.c97ff677ca825aa1254f6b7ae7d529d7c(A.c03f6a5188365ec4cf5f4047b3562ed42, System.Windows.Forms.Keys)
at A.c7df263a9b37fff7c89f4dfbfe038d49a+c6d8c98e4398d53a828be90c2f7f5c9b1.c3e150560f66705be288600db01497f5a()
at A.c7df263a9b37fff7c89f4dfbfe038d49a.c5e2de26f72570725c69d553de3d40a1c()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Threading.ThreadHelper.ThreadStart()
sysinfo.txt (2.6 KB)
