Rhino 7, 8 and 9 - Angle dimension bug
there seems to be a bug with angle dimensions arc not displayed with left side angles on these polylines.
File: Angle dim bug.3dm (2.3 MB)
Found a workaround for Rhino 8 and 9:
No workaround found in this case:
File: Angle dim bug2.3dm (2.3 MB)
I found another clue on this bug: the arc appears or doesn’t
depending on where I click on the first and second lines,
though this only applies to the example above. Is this a known bug?
Hi @Teo,
I’m looking into this - thanks for reporting.
– Dale
RH-98722 is fixed in Rhino BETA
