In the attached file, I have this weird result from DimAngle with trailing and leading zeros disabled.
Problem Dim Angle.zip (13.5 KB)
I am starting to see this same problem more frequently. I don’t know the cause yet.
Here is two in one view:
Hi Miano,
I am not sure this is what your mean, so let me know if it is not what you are asking.
You can set this unit resolution as an override on the dimension.
In the second post, can you point out the issue we need to investigate?
And can you send a model as well?
Sincerely,
Mary Ann Fugier
16°39’60" should be 16°40’
1°59’60" should be 2°
44°59’60" should be 45°Problem Dimensions.3dm.zip (16.0 KB)
Thanks, Miano!
I see it now.
I have logged RH-62416
Can you go to Rhino 7-> “About Rhino” and send the exact release of Rhino that you are using?
Thanks for your help.
Sincerely,
Mary Ann Fugier
7.2.21012.11002, 2021-01-12
Much of angle dimensions appears to be kerfluey.
I the same file I am seeing the kind of formatting I posted above as well as zero suppression is not working.
Hi Miano,
This was fixed last week in the 7.4 wip.
I will private message you about testing this.
You will not see the fix in 7.2 or 7.3.
It missed the cut off for that service release.
Sincerely,
Mary Ann Fugier
