Do we have a new Rhino Script Compiler for Rhino 6 ?
No; V6 will load and run scripts compiled for V5
Hi, i made different vbscripts, compiled with RhinoScript Compiler for Rhino 5 , so the result is that i have an *.rhp plugin that works with rhino5 bit not with rhino6.
in rhino6 the plugin is correctly loaded but is empty (no commands inside)
do you have any solutions?
thanks
@mconti Have you checked the uncompiled script runs in V6? I’ve had some scripts fail in V6 that needed small modification, after updating they ran fine inV6 and V5.
Mark
Yes, i do…
Only one script, executed with the EditScript of Rhino 6 works fine, compiled as rhp, load the script but doesn’t load the command…
Is this because on the command name i have the “_” char ???
i remove the “_” char from the name and now works fine…
It’s possible, but I’m not sure. If you send me your plug-in that doesn’t work, I could try to determine what is going wrong while loading the plug-in.
with this name works : CMSAlignserie
with this name doesn’t : CMS_Alignserie
