Rhino 6 python editor is freezing when I want to open any of the method category.
I use the latest build (6.2.18065.11031, 06/03/2018), Win 8.1
Do you by any chance have an Independent IronPython installation? (Please check in the Control Panel)
http://developer.rhino3d.com/guides/rhinopython/python-troubleshooting-install/
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
same problem here, no IronPython installation.
I uninstalled IronPython and restarted the pc. Now, it is working. Thanks
Did you check the Control Panel, or assume that you didn’t install it so it’s not installed? Some third-party products install IronPython silently.
Hi Giulio, yes, it was there, must have been installed silently. It solved the crash. Thanks.
–jarek
Hmm… any chance you remember what version of IronPython was installed? I want to try and repeat this so I can verify what I think would fix the problem actually fixes the problem.
It’s gone now, but i believe it was 2.7.3, if it makes sense at all…
