Hello!
Support’s assistance is needed with resolving Rhino installation on Ubuntu Linux through Wine and PlayOnLinux.
This will allow work in Rhino outside of a Virtualbox where GPU passthrough is needed to activate, rendering, shading and the cycles renderer for work with 3D models. Passthrough is untested due to the difficulty in blacklisting 1 of 2 same model GPUs to work with VirtualBox. VirtualBox have also dropped the capability completely in version 6.1.
Rhino Bootstrapper installer fails when used through Wine 5.0.1 stable with error:
“Download and Cache Failed with error code :0 .”
Failure occurs at:
“Installing Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.25.28508”
With an additional error pop-up of:
“The program rundll32.exe has encountered a serious problem and needs to close…”
Second attempt results in a failure at:
“Caching Rhinoceros 6 Language Pack Installer (en-US)”
With the same error pop-up:
The error pop-up needs to be closed twice before the rhino installer outputs the error:
“Download and Cache Failed with error code rhino.msi:-2147023293 .”
Tried both, installing with the conventional installer to no avail either.
Hopefully the logs attached are helpful.
