I’m just a casual user of Rhino for years, and I use it for personal projects. I thought I’d just put this out there as a possible path for getting it to run semi-reliably with Wine on Linux. For anyone encountering this post, Linux isn’t supported, don’t expect support from McNeel. I don’t even know if it’s ok to post this here.
Anyway, Grasshopper seems to work. auto-update will work occasionally on a clean boot of the workstation or after terminating all existing processes. 3D acceleration appears to work. You might have to mess with UI DPI in wine if you have a high dpi display like mine (4K)
I use cloud zoo login licensing which works seamlessly.
Here’s a github gist to the checklist of things to do.
I know this implementation can be improved with those who know more about Wine than I do.
I’ve worked in this environment now for about 10-15 hours on various projects and haven’t encountered anything particularly egregiously bad yet. I hope this helps those who need it.
Looks interesting. I’ll definitely have to regain access to my linux box and see if I can get Rhino working with your instructions. Thanks for sharing.
I’ve been experimenting with cuda libs and other things. Can’t get rhino to detect cuda for render offloading, but using wine-staging allows me to leverage wine-7.22 (Staging) which seems to then allow me to use Vulkan rendering. This, in turn, reduced the visual artifacts in viewports.
There’s still some stuff that “just isn’t right” like certain ui elements popping up as black squares. I would imagine there’s a lot of legacy technical decisions in the ui and other things within Rhino, making calls to all sorts of layers of microsoft stuff.
Windows 10 (10.0.17763 SR0.0) or greater (Physical RAM: 63Gb)
Computer platform: DESKTOP
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Here’s a short video of clicking around. I deliberately spawned the application from the terminal so you can see the callback messaging that’s happening in the background.
While Raytracing is restricted to using CPU you could go to Tools > Options > Cycles and move sharpness slider one or two ticks to the left and the responsiveness slider maybe even all the way to the left. It should help with interactivity in the viewport. The actual _Render will still be at full pixel resolution.
