There is a big library of materials in Rhino 6.
If I use these materials with Rhino Renderer,
and then switch to Vray Renderer -
Will I still be able to see the materials that I used in Rhino ?
Are Rhino 6 materials compatible with Vray 3 for Rhino?
Yes to all…
If you apply materials to objects or layers,V-Ray will do a very good job of interpreting them, textures included.
There’s also a tool that will convert Rhino materials into V-Ray materials so you can edit them in the V-Ray asset editor.
Thank you for your answer.
What is the tool that will convert Rhino materials into V-Ray materials ?
Thanks
Rachel
Hi Rachel,
try the command _visConvertRhinoMat.
Jonas
I will try it.
Thank you very much
Shame the same thing doesnt happen with brazil which is the render engine McNeel sell with rhino
Well, Brazil works with those materials out of the box.
