Continuing the discussion from Rhino 6 Material Library - Material editor is pointing to an online bitmap image but the assigned objects are black:
… also having a similar error:
File does not exist, download from http://files.mcneel.com/rhino/6.0/textures/Fabromont-Resista-Color-Punkt-Kugelgarn-Teppichboden-Carbon big .jpg failed
I have had an error message for a long time for which I cannot find a solution. The error message means that saving will probably always take a little longer. Since the file is always saved - no later than the second attempt, the problem can be “sat out”.
when saving - also with automatic intermediate saving the following line appears - sometimes 10 times in a row:
“Fabromont-Resista-Color-Punkt-Kugelgarn-Carpeting-Carbon big .jpg” is an image file that I sometimes use for rendering - but not in the files concerned. The problem persists even if I delete unnecessary layers and materials with
-> Tools / -> File tools delete all unused materials
(… what are actually predecessor and RDK materials?)
What irritates me is that when saving, a download is attempted on the McNeel page, where this JPG is unlikely to be found,
which leads to delays when saving in sequence. At least the log always gets stuck in the command line.
Where / how could I look for a solution to the problem?
anybody out there that can help? Thank you!
