Yep, Technical is very bad in V6 on this machine - thus probably any display mode that relies on the Technical pipeline like “Artistic”, etc.: V5 20 sec. / V6 130 sec.
But @Gijs - my Windows machine with a 5 year old GTX 780/3Gb does TestMaxSpeed in Rendered mode in 1.65 seconds, and Technical mode (without hidden lines checked!) in 5 seconds - so Technical mode is 3x slower than Rendered even on Windows here. With hidden lines shown Technical slows down by half again, takes 10.8 seconds. Artistic is also about that speed.
I tried using the magic mouse with Rhino and I think it caused zoom problems (and not only). Of course, each of us uses what he feels is right, but perhaps we could see if performance improves with a normal mouse.
Exactly! I don’t even expect Rhino to run smoothly with huge and overly detailed models; that’s why I made a really basic test model and it’s still not running at >30fps (when I would expect 60fps) Especially considering the render mesh has only 1112 polys.
I’m also not getting it every time, I have no idea what’s causing it. When navigating in the viewport, everything seems to run smoother compared to using testmaxspeed.
Also, I did another test using gfxCardStatus to force Rhino to use the Intel HD card. Here are my results, average of 3 runs each:
OK, I guess the Windows gaming community and cypto mining industry are the biggest markets for GPUs nowadays. CG is only a small one.
That’s not my goal at all, but there are two sides to the coin. Like @Helvetosaur explained above, Rhino 6 is optimised for newer, high-performance GPUs and most mac users have older, less performing cards.
Here’s another test with 1000 random N.u.r.b.s. cubes:
I was sure that Rhino mac 6 is years away from its release since I was shocked by the slow performance which you could feel with every mouse move an click. And since I did experience it +/- on all macs we have I thought this is simply because we are still in early development.
hmm.. I think I’m going to not post any more comparisons in this thread because I’m getting way better performance than you all.. for example, using the test model in the thread with Arctic mode for me:
Command: SetDisplayMode
Display mode set to "Arctic".
Command: Testmaxspeed
Time to regen viewport 100 times = 5.06 seconds. (19.76 FPS)
that’s a $4000 computer though.. surely can’t expect everyone to pay that for decent performance (imo).
edit-- hmm, actually, if I torture test it and set Arctic to Maximum Shadow Sharpness (which looks best to me), I then get super slow performance
Time to regen viewport 100 times = 96.96 seconds. (1.03 FPS)
edit2.. just realized I had 3 other models open when doing that so probably took a hit there.. I think it’s evident there’s a performance hit for everybody going to V6 vs V5.. so.. I’ll quit with the faulty tests
ah, cool. Makes me wonder why this isn’t done dynamically/progressively. If you rotate at full setting, it disables the AO during spinning, but could just as well degrade the amount of samples instead and keep refining when ‘still’
yeah, that would be a cool option.. allow you to set up your view with faster/degraded quality then switch to high quality after, say, one second of stillness
Do not use TestMaxSpeed to compare Mac V5 and Mac V6 performance
TestMaxSpeed is a test command. I wrote both the Mac V5 and the Mac V6 versions. They are totally different implementations and cannot be used to compare V5 with V6. We can use it internally to see if code changes made within a single version have an effect on performance.
The command was originally written for Windows Rhino, where you can force the display to be drawn when you want. That is impossible to do on MacOS. The best you can do on the Mac is request that the display be updated. Mac V5 and Mac V6 use entirely different techniques to determine whether that has actually happened, so can have wildly different timings.
If the Mac code did not check that the display has actually been updated, then MacOS optimizes out a display update when quickly followed by another display update request. Without artificial delay checks, TestMaxSpeed always takes less than 0.1 seconds, because it only draws the first and last frame. All in between frames are optimized out.
The technique used in V5 to detect display updates mostly works, but the OS can still optimize out some of the updates. V6 does a better job of this and can appear slower because it actually draws every frame.
And, all this is Independent of display mode settings which also have a huge effect on performance.
I did just use it sometimes for some screenshots since the rendered mode is more sophisticated that in V5. Unfortunately I was never really able to test V6 properly, which is a shame.
Edit:
I just tried to open my Rhino V5 Model (a project I am currently working on) but the layouts are gone. I V5 I had done ca. 10 A3 pages with detail views, but if I open the file in V6 the layouts are blank.
I will follow your advise, but: Fact is that V6 feels much slower in all display modes. Especially when zooming in and out it’s going to stutter where v5 keeps being smooth. The fact that we began comparing using testmaxspeed in the first place was because everyone notices the fact that v6 is slower.
