I have an issue with using file referencing. If I link a rhino file into another file, using “Active” layer mode the layer::sublayer structures are ignored. If I have a structure that looks like this: Building A::walls Building A::glass Building B::walls Building B::glass
than all elements from “Building B” sublayers are present in “Building A” sublayers. It is huge problem especially when using Make2D with sublayers.
Thank you for the response. This option works when I copy-paste elements from one file to another. But I think it should work the same way when you are inserting a file as a block with “Embed and link” or “Link” option with “Active” layers structure.
