Hi there,
Just wanted to check if someone had time to look into Kangaroo performance issues on a Mac?
If not, is it been fixed in WIP 7?
Here is a link where problem was described and sample files where attached.
Thank you,
Hi there,
Thank you,
Hi @arten,
Thanks again for your patience.
Which version are you currently running?
I tested a while back when you posted about this, and was able to replicate it getting extremely slow and freezing.
However, I just tested again in the current Mac Beta, and the speed seems good:
I do notice that the Grab tool is still not very responsive, and pausing the solver by toggling to false sometimes takes a moment. I’ll see if anything can be done to improve these. Hopefully you can confirm though that the overall speed is now good after updating to the latest Beta?
Also, I have improved the Escape behaviour to cancel the Kangaroo solution, so this should make it easier to stop simulations that aren’t behaving.
Hi @DanielPiker,
Glad to hear back from you. I hope you are doing great.
I haven’t tried WIP 7 yet, will give it a shot this week at some point and will let you know.
I still using Rhino 6 and still the same problem, unfortunately. If it works in WIP7 it is good I will work on Kangaroo projects in version 7.
Thank you,
Hi @DanielPiker,
Yes, I can confirm Rhino 7 Beta Kangaroo works great
Sooo much better. I don’t have to wait now.
Grab as you mentioned a bit slow though, but I am not using it too often.
Thank you!
I can confirm that. Also panning around in the gh canvas while the solver is running, works only very slowly. This is a bit cumbersome for simulations that take a long time to converge, or never converge…
Alle the best,
Rudi
