I am transitioning to Rhino 6 from Rhino 5. I have a textured OBJ, and I previously was able to see the texture and GH preview objects in rendered mode. In Rhino 6, I can’t see GH preview objects any longer (specifically curves). I read on the forums that rendered mode no longer allows you to see GH preview objects, but you could make a different display mode to make it work. Is it possible to use a custom rendered display mode that shows the material (texture) as well as GH objects? I can only see the GH preview objects if i render the object with a single color.
