If hoopsnake is failing to load, you’ll have to uninstall it.
Or you can put an empty file called Hoopsnake.no6 next to the Hoopsnake.gha file to prevent Rhino6 from loading it. Just make sure it has the same name as the plugin file and the extension .no6
