Rhino 6 file in rhino7 rendered viewport
when i opened rhino6 file in rhino 7, rendered view showed too bright and all of them in the model were showed whitish like this… . Please kindly teach me how to solve it.
Hello - open the Rendering panel, and at the bottom, click on Retset to Defaults.
Any better?
Dear Golay
Thank you for your reply.
After resetting to defaults, the situation is still the same.
best
Keisuke
Hi Keisuke - please also try resetting the display settings for Rendered to defaults in Options > View > Display modes > Rendered. Also please run SystemInfo in Rhino and post the results here.
Dear Golay
Please see the text below
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Commercial, build 2022-02-08
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 9-23-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-23-2020
Driver Version: 27.21.14.5241
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\aikawa\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.20335.757
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.15.22039.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.15.22039.13001
Best,
Keisuke
Hi Keisuke - I would disable Enscape in Options > Plug-ins page and then close and re-start Rhino - any difference?
Dear Golay
i disabled enscape but no difference is seen. also the same problem happen when i opened that file in the laptop which hasnt been installed the enscape
Best, Keisuke
Hi Keisuke -
Can you post your Rhino 6 file?
Dear Wim and Pascal
It was because of lighting problem. after deleted some groups of the lights, the problem was solved completely.
Thank you for your cooperation.
Keisuke
