I have a small project where I have multiple layers, each with color for shared view, and material set for when I want to view in rendered. The problem I am running into is that the rendered view stopped working and now does not display color - everything is white! The strange part is that if I close and re-open Rhino it works SOMETIMES!
Hi Victor -
There is not all that much to go on in your report, except, perhaps, the “SOMETIMES” part.
That makes it sound like an issue with your machine.
Please run the Rhino SystemInfo command and copy-paste that information here.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: AMD Radeon Pro 5500M (AMD) Memory: 8GB, Driver date: 11-11-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 20.45.40.15 27.20.14540.15002
> Integrated accelerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-11-2021
Driver Version: 27.20.14540.15002
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
Yeah, what you are seeing is what I used to see/expected to see. I did verify driver for GPU is up to date - latest as of 11/11/22 but that did not make a difference.
Also, yes, the materials have the correct bitmaps, and I can edit them. In fact, here’s what I am seeing:
Notice that the 3D rectangle is on Layer06 with “Grassy” as the material but yet it still shows as white… I’m thinking that something is corrupted but I am not sure why - seems like a bug.
By the way, I can replicate this on new objects as well, so it doesn’t seem to be object related.
@pascal - Ready for some more weirdness? I found a way to reproduce behavior! The color on materials do not show up(all white) if I open the file from File Explorer. If I open the drawing from the “recents” tab when Rhino first starts, the colors show!
Hi Victor, thanks, I’ll check this.
Hm, works in either case here. Is the file on the local machine - like on the desktop - or a network, or Dropbox/Google Drive sort of thing?
