Rhino 6 disappearing objects
Just trying out rhino6, been using 5 for years and objects are now vanishing from all viewports on both screens. I can still select them if I click where they should be and the properties shows them as they should be, just not visible. They seem to reappear for a time when exploded and joined, then vanish again. They seem to be objects created from a recent command, copy and paste from an inserted drawing, a boolean, create uv curves polylines etc. It doesnt look like your described video hardware and driver problems but here is what i’ve been using.
Thanks
Hello- your video driver is a couple of years old- I’d get the latest and see if that sorts things out.
I checked and Windows thinks it already has the best driver installed. Also it just doesnt look like a video or display problem. It is more like rhino is choosing not to show the objects. And I’m quite familiar with hidden objects and clipping planes. They just vanish in front of your eyes but if selected the properties show in the properties panel. Exploding makes them visible again, usually.
Hello - I would not necessarily believe Windows on this - check the AMD website for their latest driver -
This might help too - https://support.amd.com/en-us/download/auto-detect-tool
Thanks, I’ll give it a go :smile:
Hi, thread from the past,
Same problem here (Rhino 7, Mac, no mods) and couldn’t find a solution other than retrieving a previous save (which opens another Pandora box of problems).
I noticed that most of the time, it’s all the objects on a layer that disappear, are un-selectable.
Mac Guyver fix: select objects in layer by right-clicking the layer (gumball appears), copy them to a new layer (they magically reappear), put same colour, copy the name of layer 1, delete it, paste name in layer 2.
Hope this helps!
Georges
MacOS Mojave, recent powerful iMac, Rhino Version 7 (7.0.20314.03002)
Please update to the latest version (7.2) and see if it is still happening.
Hi Helvetosaur,
I’m sorry for missing this notification. I am on Rhino 7.6 now and still have the issue, which I describe more here:
EDIT: found the solution to the problem! →
